20 Most Recent Vtech ia5845 Twin Cordless Phone Questions & Answers
manual
How do i check my
Ask your telephone service provider for details on accessing their Voice Mail system. The directions may be listed in your local telephone book. You need to call the appropriate number and then login. For my provider, with the Vtech phone, I call the number and then press # . (Once in the system, I enter the code for listening to messages or other part of the menu system.)
I hope this helps.
1/19/2011 1:42:41 AM • Vtech ia5845... • Answered on Jan 19, 2011
Viewing messages on vtech 5845
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=21896
7/19/2010 5:18:26 PM • Vtech ia5845... • Answered on Jul 19, 2010
2answers
Voice mail i6725 vtech phone
ACCORDING TO THE MODEL NUMBER THIS PHONE DOES NOT HAVE AN ANSWERING DEVICE. IF YOU HAVE VOICEMAIL - YOU MUST HAVE THE PHONE COMPANY'S SERVICE FOR VOICE MAIL. IF YOU HAVE A STUTTERED DIALTONE WHEN YOU HAVE MESSAGES THEN IT PROBABLY COMES FROM YOUR TELEPHONE COMPANY. CALL THE PHONE COMPANY AND ASK FOR INSTRUCTIONS TO CHANGE THE GREETING ON VOICEMAIL.
11/14/2008 1:18:28 AM • Vtech ia5845... • Answered on Nov 14, 2008
Voicemail box
It has to be ereased for the phone only holds so many messages.
10/16/2008 4:12:30 PM • Vtech ia5845... • Answered on Oct 16, 2008
Setup answer machine
My phone echos when it plays the answering machine with my recording, how do I stop it from echoing?It is a vtech 5.8ghz phone.
10/16/2008 4:09:48 PM • Vtech ia5845... • Answered on Oct 16, 2008
Can't Connect Displayed
CAN’T CONNECT
1.Displays when one handset is on a call and the other handset presses PHONE.
2.Displays when base power is off and PHONE is pressed.You’ll
also hear a sad tone.
3.Displays when an out-of-range dial fails to connect.
RINGER OFF
The handset
THIS IS SECTION OF MANUAL. MAKE SURE THE OTHER HANDSET IS NOT ON. PRESS THE OFF KEY JUST IN CASE.
4/19/2008 5:24:42 PM • Vtech ia5845... • Answered on Apr 19, 2008
Help
CAN’T CONNECT
1. Displays when one handset is on a call and the other handset presses PHONE.
2. Displays when base power is off and PHONE is pressed. You’ll
3. Displays when an out-of-range dial fails to connect.
MAKE SURE THE HANDSETS ARE FULLY CHARGED. MAKE SURE BOTH ARE TURNED OFF, OR NOT IN THE TALK MODE. CHECK THE BATTERY TO MAKE SURE IT IS IN SECURELY IF DROPPED IT COULD HAVE JARRED LOOSE.
1/29/2008 4:41:00 AM • Vtech ia5845... • Answered on Jan 29, 2008
How to delete a phone number from directory on a vtech dect 6.0
In the link https://www.google.com/search?q=delete+a+phone+number+from+directory+on+a+vtech+dect+6.0 Did you realise you are advertising your email address to the 12 MILLION annual viewers of this site. ..
12/19/2023 4:29:33 AM • Vtech Lands... • Answered on Dec 19, 2023
Vtech cordless landline phone When I make a call to someone the other person can't hear me but I can hear them? Please help me in how to fix. Thank you
Google make model manual you have 'Mute' set on it. All questions need 'make model (what it is)' as first 3 words. ..
12/19/2023 4:27:21 AM • Vtech Lands... • Answered on Dec 19, 2023
I live in South Africa. Ordered a vtech 2 handset phones, DS6621-2 on Amazon & it came with 12 volt charger for main cradle. Can I get 6 volt charger with the right fitting and if so, how?
You are heading at this from the wrong end. The power to the device from the charger remains the same. If the device runs on 12 volts, it needs 12 volts. South Africa runs on 230 volts, so if you bought a 110 volts version, you buy an adapter that takes 230 mains voltage in, and delivers 12 volts DC to the phone. The phone won't run on 6 volts. 230V South Africa operates on a 230V supply voltage and 50Hz. ..
12/19/2023 4:25:51 AM • Vtech Lands... • Answered on Dec 19, 2023
Why does the letter A stay in my window of my Vtech answering machine
Google make model manual It likely means the Answering system is set or not set. https://www.google.com/search?q=letter+A+in+window+of+Vtech+answering+machine 'make model (what is is)' in all questions, first 3 words please. ..
12/19/2023 4:19:55 AM • Vtech Lands... • Answered on Dec 19, 2023
2answers
Vtech cs6649 shows incorrect date and time on caller id
i like this site
12/4/2023 11:27:02 PM • Vtech Lands... • Answered on Dec 04, 2023
Deleting pre recorded answer message on vtech fs6424a
Remove greeting from the voicemail
12/4/2023 3:50:13 PM • Vtech Lands... • Answered on Dec 04, 2023
VTech CS5249 phone. How do I unmute the ringer?
Page 29 and 59 of the manual refers. Page 23 Point 16 is probably the reason. The Ringer Volume is at Zero. https://cdn-web.vtp-media.com/products/CS/CS5249/CS5249-X_WEBCIB_V2_210710.pdf a neat trick is to press CTRL+F on your computer and type 'ringer' and press Enter. There are 47 mentions of it. ..
10/24/2023 11:47:28 PM • Vtech Lands... • Answered on Oct 24, 2023
One handset on Vtech CS6919-2 has a loud buzz. I bought one CS-6919 to replace but but I cannot register it?
i can,t find my imei # for my vtech cordless landline phone. model #is cs6919-2 & the s/n is uf 203447732 all i can on the is these two numbers.i need the imei# to get it turn back on.can you help me please,please.please get to me [email protected]
10/23/2023 3:45:14 PM • Vtech Lands... • Answered on Oct 23, 2023
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.This phone system has two features.Answerphone system which records messages to the unit.andVoice Mail System which is an extended (often paid) service from your telephone provider.Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.Page 32 refershttps://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdfRetrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply. Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically. Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33 Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone...
10/21/2023 8:04:01 PM • Vtech Lands... • Answered on Oct 21, 2023
Date and time not correct when listing to voice mail
Possible battery is down. Refer to page 58 of manual CS6529-4B_UM_V5_20141120.pdf (vtechphones.com) for further details.
9/15/2023 1:43:33 PM • Vtech Lands... • Answered on Sep 15, 2023
Vtech ia5845 Twin Cordless Phone Logo
21 questions posted
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Vtech Lands Phones
  • Vtech Lands Phones
Most Popular Question
voice mail i6725 vtech phone
  • Lands Phones
