20 Most Recent Uniden Cordless Telephone Questions & Answers
Then that phone either needs a new battery or the charger is defective or the hand set is defective. These are not repaired just replaced.
Uniden Cordless... | Answered on Mar 28, 2011
You can download the user manual for Uniden DECT 1580 series from below link
http://www.uniden.com/pdf/DECT1580-3om.pdf
Thank You
Uniden Cordless... | Answered on Aug 10, 2010
You can download the appropriate manual from the manufacturer's web site at http://uniden.com/index/manuals_results.cfm
Uniden Cordless... | Answered on Jul 22, 2010
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
Uniden Cordless... | Answered on Sep 04, 2009
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
3) The answering system announces the current time and the number of messages
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
* For the Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Uniden Cordless... | Answered on Jul 09, 2009
PIN is a number, I think it stand for personal identification number, anyway he should have explained that to you. So you should have a number which you can dial into your phone. Ring them back if you are still not sure and make sure they tell you what you need to know. Good luck
Uniden Cordless... | Answered on Apr 27, 2009
Something may have failed in the base unit but there could be a telco problem that is cutting off service. If you can substitute a different phone and still don't get a dial tone, contact your telco to find out why.
Uniden Lands... | Answered on Nov 08, 2020
What is phone system connected to ?
A land line ?
what sort of diversion ?
unconditional *21{phone number}# #21# to turn off unconditional
no reply / busy ? https://infinititelecommunications.com.au/network-feature-codes/
https://www.telstra.com.au/small-business/online-support/category/bundles/dot/where-can-i-find-a-list-of-feature-access-codes
Uniden Lands... | Answered on Oct 12, 2020
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Uniden Lands... | Answered on May 25, 2020
Call the phone provider you are using, (verizon, att, etc.) they can help you to reset the password.
Uniden Lands... | Answered on Mar 27, 2020
Hello Lynn:
Make sure the power cord is securely plugged into the telephone base. Plug the telephone base into a different working electrical outlet not controlled by a wall switch. Move the handset closer to the telephone base. It may be out of range. Reset the telephone base by unplugging the electrical power to the base. Wait for 15 seconds and plug it back in again. Allow up to one minute for the cordless handset and the telephone base to synchronize. Other electronic products such as HAM radios and other DECT phones can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Do not disturb or silent mode may have been enabled. Without the model number of your phone, I might miss one of the ways to re-enable ringing for your model. Make sure that the phone is in standby mode. Next, check if there is a DND button on the base for the cordless phone system. If the LED for the button is lit, press that button. You may need to hold the button; enabling Do Not Disturb requires a press and hold.
To disable silent mode, press and hold Silent on either the handset or the base. On the handsets, this may be the # key (below the 9). When you enable Silent Mode, you can get a prompt for how long you want the phone to be quiet. If you do not press any number key (other than 0), the Silent Mode will last until you disable it manually. You can then confirm the Silent Mode or it will be enabled after 5 seconds.
I hope this helps. In both modes, the answering system will automatically be turned on if it wasn't on before enabling the mode.
Uniden Lands... | Answered on Jan 30, 2020
message light
press menu
scroll to settings then to global settings press menu scroll to vmwi and press enter
scroll to yes , press menu then end
most started after changing to NBN
Uniden Lands... | Answered on Nov 10, 2019
Select the channel, press 0, press E
Uniden Lands... | Answered on Nov 06, 2019
You don't state if the unit is on charge when it happens, or if it is all the time. You also do not state what model, and Uniden makes hundreds of products. But, it is probably an inadequate load on the charger, which would mean the battery is toast.
Uniden Cordless Telephone Logo
11 questions posted
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
one cordless telephones not working
  • Lands Phones
