20 Most Recent Uniden DCT758-4 Phone Questions & Answers
Hello Dmark,
2.4 Ghz is a fairly common household frequency...
Conflict with other systems COULD ALSO
be your problem...
ASSUMING you have had this system
same place, same usage... and have added
NOTHING in your house
(like wireless Cameras, DOT, ECHO, ALEXA, etc.).
There comes a point in the owners of a
DCT758-4 Uniden system's life...
When it is time to check the base battery contacts...
BATTERY charge indicator... and general system
performance;... (battery indicator).
Only the MAIN base is the RADIO BASE...
Depending on battery condition...
You might want to TRY moving your weaker
hand sets around to more appropriate locations...
Failing that...
YOUR BATTERIES ...
(I have shown below) are widely available
from places like eBay and AMAZON...
I am showing AMAZON for informational purposes.
FREE SHIPPING figures PROMINENTLY in my
BATTERY BUYING... So I use TRUSTED SELLERS
on eBay...
(USA: $3 - $5 each (Battery cost for your phone) .
Happy hunting...
Hay un problema muy pequen(y)o.. (not English)
Uniden DCT758 3 DCT Cordless Phone Manual Del Usuario Page 6
Uniden DCT758-4... | Answered on May 12, 2017
replace the phone cord
Uniden DCT758-4... | Answered on Apr 27, 2012
The SYSTEM RESET menu of your DCT758 base station is accessed by following these steps:
I hope that helps.
____________________________________________________
Download Uniden DCT758 Cordless Phone Manual Here.
Uniden DCT758-4... | Answered on Apr 21, 2010
Tip
Uniden DCT758 Manual Download
Models: DCT758 / DCT7585 / DCT7085
Have you misplaced your Uniden DCT758 Cordless Phone Owners Manual?
Would you like a digital, searchable, pdf version of the Uniden DCT758 Base Station Users Guide?
Follow this link
to download a pdf version of the operations manual.
I hope that helps.
on Apr 21, 2010 | Uniden DCT758-4 Phone
Try opening the phone battery compartment on the back of the phone, disconnecting the battery wire, then reconnecting the battery wire. Solved my "Out of Range" problem - phone came back on and worked properly.
Uniden DCT758-4... | Answered on Nov 16, 2009
http://www.retrevo.com/s/Uniden-DCT758-Telephones-review-manual/id/471ag403/t/1-2/
Above is the manual for your phone ,read pages 13-21 and should help you out.
Uniden DCT758-4... | Answered on Nov 06, 2009
Press menu, go to system reset, base unavailable, yes and place on main base to re-register.
Uniden DCT758-4... | Answered on Mar 17, 2009
There is delete key , left bottom side of LED frame. , Looks like (/) , when you play the message( |>) , then press delete key(/)
Uniden DCT758-4... | Answered on Feb 21, 2009
After you play your messages, press the button on the left side of the on/off button...the one above the charge light. It looks like a circle with a line through it???
My maching isn't working right now or I would be able tell you exactly what the voice sais, but it is something to the effect of "to delete messages, press delete again." Just press that button again and it should delete everything.
Hope it works for all of you!!
Uniden DCT758-4... | Answered on Jan 09, 2009
If you tried the registration process discribed in the book, it is possible that the base may have gotten zapped. Happened to me. Bought a new DCT 758 (cheap at Amazon.com) with only one extra handset and used two of the old handsets with it. It will only support the handset in the base and 3 others, so you can't use all of the old ones (save them for extras).
Uniden DCT758-4... | Answered on Jun 03, 2008
if they are less than a year old you should be able to bring them back under warranty and get them replaced. sounds like they might have got a power spike and it killed the base.
Uniden DCT758-4... | Answered on Jun 09, 2007
Something may have failed in the base unit but there could be a telco problem that is cutting off service. If you can substitute a different phone and still don't get a dial tone, contact your telco to find out why.
Uniden Lands... | Answered on Nov 08, 2020
What is phone system connected to ?
A land line ?
what sort of diversion ?
unconditional *21{phone number}# #21# to turn off unconditional
no reply / busy ? https://infinititelecommunications.com.au/network-feature-codes/
https://www.telstra.com.au/small-business/online-support/category/bundles/dot/where-can-i-find-a-list-of-feature-access-codes
Uniden Lands... | Answered on Oct 12, 2020
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Uniden Lands... | Answered on May 25, 2020
Call the phone provider you are using, (verizon, att, etc.) they can help you to reset the password.
Uniden Lands... | Answered on Mar 27, 2020
Hello Lynn:
Make sure the power cord is securely plugged into the telephone base. Plug the telephone base into a different working electrical outlet not controlled by a wall switch. Move the handset closer to the telephone base. It may be out of range. Reset the telephone base by unplugging the electrical power to the base. Wait for 15 seconds and plug it back in again. Allow up to one minute for the cordless handset and the telephone base to synchronize. Other electronic products such as HAM radios and other DECT phones can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Uniden DCT758-4 Phone Logo
Popular Tags
19 questions posted
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
handset says out range
  • Lands Phones
