20 Most Recent HP CTO HP Workstation XW6200 Base (DY247AV#ABA) PC Desktop Questions & Answers
Sound not working after reinstalling pc
If this machine is running XP, or earlier (98, 2000, ME, etc.), beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine, or don't try to get on the Internet with this one.
8/2/2014 7:58:05 PM • HP CTO HP... • Answered on Aug 02, 2014
No sound after reinstalling windows xp professional
Shine a torch (flashlight) onto the motherboard to pick up any clues as to what processor or chip is driving the sound. Or install Speccy or Belarc Advisor to see what's inside. Better still, Device Manager & find the properties of any components that aren't yet active & happy, then search for the drivers. Good luck!
6/14/2014 11:08:22 AM • HP CTO HP... • Answered on Jun 14, 2014
When i press power button it refuses to put on
change the power supply
3/9/2014 3:16:05 AM • HP CTO HP... • Answered on Mar 09, 2014
Beeping wheneve the switch on the system
Try http://www.computerhope.com/beep.htm first to find out which component is failing. If possible, take the cover off & reseat everything you can see. If all else fails, take it to a computer shop.
1/23/2014 8:36:42 AM • HP CTO HP... • Answered on Jan 23, 2014
HP xw6200 power led blinks orange blinks nine time at the time continuously when connected to power, it won't stay on. Power light continuously blinks orange nine times at the time
Seehttp://h50146.www5.hp.com/lib/doc/manual/workstation/xw6400/364898-001.pdfPage 110 - M/B or Processor fail.
1/28/2013 3:06:11 AM • HP CTO HP... • Answered on Jan 28, 2013
Hp xw6200 orange blinking power light
See the following manual:http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/c00213035.pdf
1/25/2013 1:00:09 PM • HP CTO HP... • Answered on Jan 25, 2013
My hp does not boot
hp has a problem with the power supply - it is always too small for the application. go to the site absolute solutions and order a new power supply.
10/18/2009 1:38:29 AM • HP CTO HP... • Answered on Oct 18, 2009
Xw6200 gives 6 beeps but goes no further,
on any type of desktop o laptop computer, you can access the BIOS settings by pressing at DEL key while it turns on (in some computers you will see a message on the screen after you turn it on displaying the right key to press in order to get into the bios settings.. from there you can look true the options and clear the settings and reset the machine to safe mode o factory settings.
If you can't get in any option at all you need to open up your computer, make sure the FAN on top of the CPU is working. it may gone bad and your computer is overheating. by default it will shut down after the beeps.
if the fan is ok, try pulling the memory ram stick off the slots. turn your pc on, see what is instructed on screen if there is any info.
iffter taking the memory ram modules off, if you have more than one try to just put one at the time and see if if boots up as normal. then just put the second on and if this cause a problem just remove the second memory module and it will be the answer to your problem
TERRY
10/7/2009 2:24:19 AM • HP CTO HP... • Answered on Oct 07, 2009
HP Workstation XW6200 starts to power up and then
First open cpu cabinet.
Then Refix your RAM memory .
Reattach ATX power connector from SMPS to motherbord.
Remove pci cards from PCI slot.
Pull cmos cell from motherbord for 10 minutes so all motherbord settings are defaults.
Reattach both connection to harddisk.
Make sure your harddisk is detected in bios.
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then check harddisk is detected.
Let me know if you need more assistance.
Thanks.
10/4/2009 11:45:15 AM • HP CTO HP... • Answered on Oct 04, 2009
Pc beeps five times when swtched on
PC beeps are usually memory-related problems. make sure you are using the right memory for your computer. the specs should be a DDR2 DIMM 240 pin PC2-3200. what specs do you have?
also do you have two 1G memory sticks or just one 2G memory stick? it may be that your computer doesn't accept a 2G memory stick but rather 1G memory sticks. good luck.
12/26/2008 2:25:07 AM • HP CTO HP... • Answered on Dec 26, 2008
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered 2 days ago
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
2answers
What to try now hp omen dv7 battery issue
If calibrating the battery didn't work for you you could try a hard reset of the battery:
3/6/2024 9:11:06 PM • HP Computers &... • Answered on Mar 06, 2024
HP CTO HP Workstation XW6200 Base (DY247AV#ABA) PC Desktop Logo
Popular Tags
14 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp xw6200 orange blinking power light
  • Computers & Internet
