20 Most Recent
HP Pavilion a1430n PC Desktop Questions & Answers
My Hp Pavilion a1430n tower is beeping
If your display not coming or beeping, then RAM issue. So you change ram solved you problem. But you are ask display come and that beeping come. I suggest you format windows and proper installed it. Because Installation time if installed without error ok, other wise HDD or RAM issue found. Then you change device and installed it windows and used it PC.
Thanks.
TechSupportMart
Computer Support
Wifi connection fail
you may be are far from the access point device or your password may be incorrect.
Wifi antenna
More usually than not this turns out to be a driver issue... Please tell us the exact model of your wifi antenna , so that we can help you find the most appropriate/latest driver for it (if you do not wish to look for it by yourself...)
I installed a new version
Got to this site:
HP a1430n Support
Click on the Software & Driver Downloads link. You will then have to select your operating system. Then it will list available drivers and other software that is available.
Thanks for using Fixya.
Computer is running very slow. New power supply
Usually heat and / or bad sectors on the drive will slow it down.
You should take the desktop outside and with TWO cans of compressed air blow out all the dust.
Let us know if that fixes the issue or not and we'll proceed from there.
When turning on computer hp 1430n it does not
no it's not bios isuue
your have proble may with folowing devices
1 chack your HDD
2 cahck RAM if when u start and getting beep
3 windows is not working properly u have to repair your windwos
this are problem you have to chack first
Are the ports etc. labeled on the back of the hp
The connectors have legends but not labels. You can download this
setup poster from HP
which shows you what the connectors are for. Any printer you connect will likely be a USB printer (about the only kind available today). You can connect those to one of the front panel USB ports and not have to bother getting behind the computer at all.
You shouldn't have too much trouble. Thanks for using Fixya!
Sound does not work for monitor speakers.
You should try installing all the drivers included on your monitor. After installing the drivers, you should select the monitor speaker Audio output from your Sounds and Audio Devices Properties.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
The airplane mode button is stuck on orange although my computer say's airplane mode off
old PCs do that, for many reasons. but no PC told at all just HP.
40 years of PCs ,10000 + models nobody can guess ever.
but I do have the answer, in pure generic form.
did you buy the PC like that used and bad Wifi. ?
- the wifi card is missing, as was super common 10+ years ago.
- someone put in the wrong card, not from HP list
- HP blacklists (bios blocks) none HP cards (wifi)
- the card needs a driver to work if not it is dead or 1/2 dead.
- the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
- The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
