20 Most Recent
Epson Stylus 680 InkJet Color Printer Questions & Answers
Only want to use blkac ink only
When you want to print a page whether its a word page or any webpage as you give that print command before printing you will find many options in the left hand side like Destination,pages,layout,COLOR,margins options, So before printing the page you can easily check in the "black and white" option and it will simply print in black. If the information helped you then please give me some ratings.Thankx
How do I set my stylus 680 to print grey?
If you mean you would like to print in greyscale, and not colour, Right click on the printer icon / printing preferences / advanced / then tick the box that says greyscale in print options
ON button flashing and next
Reset the printer by pressing and holding the power button from 5-8 seconds until it shuts down. Turn it back on and it should work.
Green light flashing and ink
Hi!
Try to look for a ruler or something that will make you press the cartridge cover fully. It may be loose or not snap in properly thats why the cartridge holder won't go all the way.
Hope this helps.
I do not have a
DOWNLOD THE DRIVER HERE http://driverscollection.com/?H=Stylus%20Color%20680&By=Epson AND INSTALL IT.. HOPE IT HELP..
How could i know if
Your Printer's Status Monitor tells you when the ink in your ink cartridge is about to run out. However, the Status Monitor is not always accurate. If, you turn off the status monitor, the only sign that will tell you that your ink has run out is that if your printout has white streaks or lacks the other colors.
Epson stylus color 680:
chek th eprint mode is it colour and the catridge is not empty.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Flashing lights won't stop
Hi Good day!! This error means that some mechanical parts of your printer is in trouble. This could be some of the causes:
1. The print head is stuck somewhere or is unable to move because of some blockage in the printer's bay.
2. If you are using a Continuous Ink System, then the tubes might have blocked the print heads from moving.
To resolve, turn OFF your printer. Remove such blockage then turn the printer back ON.
Regards,
JR
Epson colour 680 green and red lights on, will not
- Pressing and holding LOAD/EJECT and CLEANING buttons,
- press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
- Release all buttons.
- In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
I carried the printer downstairs
Have you tried taking out and reinserting the ink cartridges? Also if need be try reinstalling the drivers and go from there. Let me know how it goes and if you need further assistance.
Thank you,
Lee
Power light flashing and red light on button 2
Hi
Thanks
for using FixYa. There are two step-by-step procedures to resolve the issue—
Procedure
- Turn off the printer and ensure
that the print head is at its home location and locked in place as normal;
- Power off the printer at the
wall or by removing the power cable for at least 20 seconds;
- While you restore power to the
printer at the wall socket or by reinserting the cable, if the lights come
back on straight away, the printer’s power switch was ‘on’ - switch it off
and return to step 1;
- Hold down the paper-feed button
and the button with the ink-drops next to it, and then turn on the
printer, still holding the buttons down;
- When the paper-out LED flashes,
release the buttons;
- Press and hold the Cleaning
button, until several lights flash - this will take a few seconds then
release the button;
- The printer will now attempt to
reset, including resetting the EPROM memory and running a short (about 10
seconds) cleaning cycle.
Procedure
that the print head is at it’s home location and locked in place as normal;
- Hold down the paper feed button
only;
- Turn on the printer;
- As the paper feed light starts
flashing, release the button;
- Immediately hold down the ink-drops
button for some 10-20 seconds or until the printer springs into life;
- Allow printer to complete its
processing then turn it off for a few seconds and turn it again on.
By following the above any one of the step-by-step
procedure, the printer will start printing normally.
Please do
rate the solution and revert for further
assistance.
Thanks
Rylee
I used a substitute black ink cartridge and now
if you light is flashing alternatively, this mean the waste ink counter need to be reset and the waste ink pad need to be replaced.
you will need to download the resetter the link below..
http://inkjetprinterhelp.us/epsonSSC.html
