20 Most Recent Konica Minolta Bizhub C360 Questions & Answers
Remove paper from finisher tray
check the exit sensor Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/25/2018 5:55:09 PM • Konica Minolta... • Answered on Mar 25, 2018
Where is ozone filter located on bizhub c360
left side rear, mid Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2018 4:02:56 PM • Konica Minolta... • Answered on Mar 11, 2018
Konica Minolta Bizhub C224e code error E310?
no 310 but is 301? incorrect memory Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2018 11:29:23 PM • Konica Minolta... • Answered on Feb 19, 2018
C-F907 bizhub C360 -
sir, MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2017 7:56:28 PM • Konica Minolta... • Answered on Mar 11, 2017
Error sortout
Conduct the following setting. [Service Mode] ? [Memory/HDD Adj.] ? [Memory Check] ? [Detail Check]. When "NG" is displayed, replace the appropriate memory or PWB. WORK0: DIMM0 WORK1: DIMM1 FILE0,1: MFP board Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/25/2016 10:17:20 PM • Konica Minolta... • Answered on Dec 25, 2016
BIZ HUB C 360 AFTER 5 PRINT ERROR SHOW C 2558 OPEN FRONT DOOR & CLOSED , COPY QUALITY IS OK
Looks like Black Developing unit malfunctioning. Replacement is the permanent solution..
12/25/2016 7:16:02 PM • Konica Minolta... • Answered on Dec 25, 2016
What is error 550
replace the fuser, if not then check control board Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2016 5:38:09 AM • Konica Minolta... • Answered on Jul 04, 2016
Bizhub c360 error code 12
l-12 or p-12 code???????????????????????????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/23/2016 11:55:27 PM • Konica Minolta... • Answered on Jan 23, 2016
Konica Minolta Bizhub C360 is printing colour lines on the sheet.this happenned after changing the black tonner.how do i solve this problem
What color are the llnes, replace that color image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 5:00:16 AM • Konica Minolta... • Answered on Jan 18, 2016
Error c3451
no such code Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/14/2016 4:07:37 AM • Konica Minolta... • Answered on Jan 14, 2016
Konica bizhub setup problem
then get a tech out set up is not easy the copier arrived not together? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/14/2016 3:55:10 AM • Konica Minolta... • Answered on Jan 14, 2016
Cyan developer finish in 1 months
must have used a lot of cyan or a bad cyan image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 3:51:57 AM • Konica Minolta... • Answered on Jan 10, 2016
A print job deleted accidently
no just resend it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 9:24:44 PM • Konica Minolta... • Answered on Dec 30, 2015
Konica minolta bizhub c360 cannot stabilize color
what code is showing what do images look like???? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 5:08:19 AM • Konica Minolta... • Answered on Dec 30, 2015
Konica minolta color stabilizer is not working
Is there a code? how do you know????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 4:48:45 AM • Konica Minolta... • Answered on Dec 30, 2015
Put in a firery now machine gives error code c-d252 hw do i remove that
Missing the VI-505 relay board. Also check in service mode that the Image Controller setting is set to 0. Also mite have a bad main board, and or relay board if installed. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
10/31/2015 10:45:53 PM • Konica Minolta... • Answered on Oct 31, 2015
Fan runs continuously
Which fan location? any info on the control panel? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/30/2015 9:52:34 PM • Konica Minolta... • Answered on May 30, 2015
Konica c2253
One of the drums is unable to turn, pull each one out. check them, physical turn drum make sure you turn them correctly, and use the edge of the drum not just put fingers on any part of the drum, might. one at atime hav to get a color drum and black drum they are different and replace the black if not that the replace the color one Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/26/2015 12:47:12 AM • Konica Minolta... • Answered on May 26, 2015
Konica Minolta Bizhub C360 Logo
Popular Tags
34 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
carpediemweb
Level 1 Expert
George Mclaughlin
Ekse
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
solucion codigo cf902 konica minolta
  • Office Equipment & Supplies
