20 Most Recent
Konica Minolta Bizhub C 6501 Color Copier,ic 408,bizhub 6500,only 442,000 Copies Questions & Answers
Konica minolta 6501 error code c-c101
had a circuit board replaced recently??? if so check each and ever connection, pull each connection and reseat each connection one at a time while each connector is removed check all pins for a bent pin. Or replace the Print control board, Interface control board, image control board, and the overall control board, $$$$$$$$$$$$$$$$$$$$$$$$$ more then what you paid for the machine!!!! Then you will still have to remove each connection and reseat them and look for bent pins!!!!! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
