20 Most Recent Konica Minolta Minolta Di 650 Di 551 Di 5510 Di 7210 Copier Toner 604a Questions & Answers
what code???????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 10, 2018
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem with the fuser (The Hot Part) the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Konica Minolta... | Answered on Jan 18, 2016
clean and inspect the drum cartridge replace the drum and the cleaning blade when was last time pm was done do be done ever 250,000 copies do one.
Konica Minolta... | Answered on Jan 15, 2016
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Konica Minolta... | Answered on Jan 10, 2016
try this site for parts as a start
What do you mean yo cleaned the control board?? Did you remove it????? IF you did major problem a Will have to go back and remove each connector looking for a bend pin and ensuring each connector is properly seated. Never remove board unless required. As for the code: please check code could not find in the service manual
Konica Minolta... | Answered on Dec 28, 2015
C1450 Sequence timeout. Good luck with that
Konica Minolta... | Answered on Oct 26, 2015
Check the actuator if deform or sometimes a small torn off paper remains on it. Position the leve A down steady before pull.
Konica Minolta... | Answered on Dec 03, 2014
Minolta Di 750 error code SC-23-01 i want solutions this code.
Konica Minolta... | Answered on Nov 25, 2013
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Konica Minolta... | Answered on Sep 24, 2020
The Printer Is In An Error State also appear in more wrong with the all inappropriate printer driver and also need to renew the driver to retaliate problems of this kind. You can handle the best way and deal with the drivers is easier. Then, the driver is easy and more intuitive to recognize with your system and find out the all correct drives. You can access to need about the specific system your computer is running.
Reasons that cause Printer Is In An Error State:-
1. Perhaps the drivers are not installed correctly.
2. Indicate if you have downloaded the drivers and software relating to your printer model.
3. Attachment issues can also be the root of this printer error state issue.
4. BIOSS issue is a very simple factor in giving rise to this daunting issue.
5. Perhaps the wires or USB wires are not attached well.
Just follow the steps which are mention on the blog to fix the Printer Is In An Error State. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER in our BLOG.
Konica Minolta... | Answered on May 29, 2020
https://www.manualslib.com/manual/837626/Konica-Minolta-Bizhub-162.html?page=174
Konica Minolta... | Answered on May 05, 2020
Konica Minolta Minolta Di 650 Di 551 Di 5510 Di 7210 Copier Toner 604a Logo
12 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
error code sc23 03
  • Office Equipment & Supplies
