20 Most Recent
Konica Minolta 2 Pack Bizhub C-250 C-250p C-252 Tn-210m Magenta Toner Questions & Answers
When i power on the machine it give the error C-D307
Abnormality is detected by the abnormal check of each NVRAM Data. Need to have tech come out try to re flash the firmware on the machine worse case you need a new control board and the Non Volametile memory is gone which house certain counter info and boot info for the copier not available on the internet only secure site at Konica Minolta they want to protect their software Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Download driver?
you can download free drivers check the link
http://adf.ly/7358038/free-drivers-bizhub-c252
Error 2554
C - 2554 Abnormally high toner density detected magenta TCR sensor.Clean the TCR sensor window on the underside of the imaging unit,reinstall imaging unit if neccessary change the imaging unit.
What is c2559
C2559: Cyan TCR Sensor adjustment failureClean the TCR Sensor window on theunderside of the Imaging Unit if dirtyorChange Imaging Unit
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
