20 Most Recent Konica Minolta Minolta Bizhub C253 Copier Questions & Answers
Code C3423
Description : Fusing heaters trouble (pressurizing side).
After warm-up operation starts, the fusing pressure roller thermistor does not detect a temperature as high as a predetermined one though a predetermined period of time has elapsed.
- The temperature of the pressure roller remains lower than a predetermined level even after the lapse of a predetermined period of time after a temperature correction.
Remedy :
1. Check the fusing unit for correct installation (whether it is secured in position).
2. Check the open/close operation of the upper right door.
3. Check the fusing unit, PRCB and DCPU for proper connection and correct or change as necessary.
4. Change fusing unit.
5. Change PRCB.
6. Change DCPU.
Konica Minolta... | Answered on Nov 07, 2019
You take a picture of the device's screen.
Konica Minolta... | Answered on Mar 01, 2019
remove all of the image units, shake each one so as to have the developer in each unit be spread out along the entire unit not at one end, after doing that to each one install them properly. open close front door to clear code if it come back if these image units are third party get real Konicaminolta units and get a tech out
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 10, 2018
try to go to your printers and faxes it is located in the start menu.
Konica Minolta... | Answered on Aug 26, 2017
replace it
Konica Minolta... | Answered on Jun 18, 2016
replace the image unit
Konica Minolta... | Answered on May 14, 2016
replace the yellow and magenta image units
Konica Minolta... | Answered on Jan 14, 2016
replace the black image unit
Konica Minolta... | Answered on Dec 30, 2015
DID Some one recently replace a color image unit? Was that image unit stored standing up? and placed directly into the machine.? Might have all the developer sitting at one end and motor can not turn. Pull out all the image units, shake each one along the axis of the unit to spread the developer over the entire length of each image unit, then re-install, open close front door to reset code, if the code comes back you might have a burn out color image motor, or on of the color image unit needs to be replaced replace all three, worse case the board that controls the motor was damaged. Store all Image units and toner length wise
Konica Minolta... | Answered on Nov 18, 2015
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Konica Minolta... | Answered on Nov 14, 2015
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Konica Minolta... | Answered on May 30, 2015
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Konica Minolta... | Answered on Aug 21, 2014
If you have a Fiery rip fitted to the machine then the standard network settings in the admin menu will not be there.
you need to click on the (i) icon on the front screen of the copier and this will open the fiery menu.
from there you can select print pages>config page and find all the details you need.
hope this helps
Konica Minolta... | Answered on Apr 07, 2014
Enter in the service mode and select tes mode select gradation test pattern and make a test for black,cyan,magenta and yellow.If the gradation is not OK you have change the bad imaging unit,or change the developer and drum in the bad image unit + the chip.
Konica Minolta... | Answered on Mar 25, 2014
Konica Minolta Minolta Bizhub C253 Copier Logo
23 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
konica minolta bizhub c253
  • Office Equipment & Supplies
