20 Most Recent Lanier Ld 116 115 118 120 316 320 320 Lower Fuser Questions & Answers
I not sure why you need to do a reset for? Did you refill your toner cartridges and your printer still wont print, showing a message in effect stating " Printer Cartridges Empty " or something to that effect, I can tell you hoe to reset the printer to accept the newly filled cartridges. (1) Turn off your computer then power down your printer. (2) unplug the USB cable where it enters the printer. (3) Power up your printer and remove all cartridges. (4) Make sure the cartridges holders are in the locked position and power down your printer , wait 20 seconds then turn it on again. (5) repeat the power on/off cycle 5 times leaving the printer power on long enough for it's " seek and find " cycles typically about 8-12 seconds. This will reset the printers count memory of the last 5 cartridges used. This procedure will work for MOST printers that use a RF IC chip that monitors how many pages have been printed by the printer. This is especially true of Lexmark printers, the number one printer manufactures who uses this technology. When you post questions in any forum here, try and leave the make, model number and the specifics of the nature of your problem. Without any further details I would be shooting in the dark in regards to doing a factory reset. A reset to accomplish what end result. if your question is in regards to doing a reset to get your printer to accept a refilled toner cartridge, above mentioned procedures should work. BOL.
Lanier Ld 116... | Answered on Feb 19, 2015
ricoh-usa.com
Lanier Ld 116... | Answered on Dec 14, 2014
yes it can be purchased seperatly.,
Lanier Ld 116... | Answered on May 20, 2014
https://www.youtube.com/watch?v=Ct6ADVdtBIg
Lanier Office... | Answered on Apr 10, 2020
All printers are not equal. Some utilize cartridges with ink reservoirs and print heads all in one. Some only have a Separate Print head carrier with a main print head and slots for ink-filled reservoirs. You can purchase and use less expensive cartridges from on line vendors. If you elect to refill carts, be prepared for a messy venture. What many printer users fail to recognize, is the print heads do wear out and prior to complete failure, the heads either cause streaking or poor color density. To clean a print head, run under the tap for a few minutes, very hot water on both sides , metal bars and where the ink enters. When all signs of ink have vanished, replace in the printer. Do not touch metal contacts as oil will interrupt electrical communications. Do a printer test and alignment. Should work.
Lanier Office... | Answered on Feb 08, 2018
http://www.productmanuals.org/lp/?brand=Lanier&utm_source=adcenter&utm_medium=cpc&utm_term=lanier%20manual&utm_network={}&utm_campaign=FM+Brands+02-03+2
Lanier Office... | Answered on Jan 06, 2018
Are these new or refilled?
Lanier Office... | Answered on Nov 09, 2017
Lanier Ld 116 115 118 120 316 320 320 Lower Fuser Logo
3 questions posted
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Office Equipment & Supplies
Most Popular Question
reset sc code lanier ld115
  • Office Equipment & Supplies
