20 Most Recent Toastmaster (TMHP2) Electric Kettle Questions & Answers
The spout filter in my Toastmaster TEK17W kettle
The filter for a Melitta MEK17W or Toastmaster TEK17W (identical kettles)are the same. If you still have the old original filter, here is the link to an inexpensive and permanent repair option using stainless mesh: www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
5/21/2016 6:04:17 PM • Toastmaster... • Answered on May 21, 2016
Is it possible to purchase
Hi.
The filter is available but price with shipping is over $10. Below cheapest option and regular price option. The part is the same.
Here the cheapest option available at $ 9.99. Click on the link and then click on the "add to cart" button on page to purchase.
You can purchase the scale filter also here at $19.99. Click on the link and then click on the "add to basket" button on Amazon page if you want to purchase the filter from Amazon.
Regards.
Ginko
9/6/2011 1:25:23 PM • Toastmaster... • Answered on Sep 06, 2011
Why does the metal in the bottom of the kettle turn green
Your water may have copper in it (or the heating element). When you boil the water you are left with the residue just like you are left with the lime scale. Vinegar should be able to remove both types of stains.
6/17/2010 3:54:31 PM • Toastmaster... • Answered on Jun 17, 2010
Manual for waffle maker toastmaster 252
Here's a copy of my W252 manual. 24105021-uzu1qvnb2cpnc32itky5hr3p-4-0.jpg 24105021-uzu1qvnb2cpnc32itky5hr3p-4-1.jpg
12/19/2020 6:29:03 PM • Toastmaster... • Answered on Dec 19, 2020
Electric kettle stop working
Disconnect the wire and open up the thermostat if its not heating up the water or not automatically stops after heating. Replace your Electric Kettle Thermostat with a new one. Because most of the problem occurs when your thermostat does not work properly. And about a 10 percent chance is your heating Element is getting wrong.
10/1/2020 9:08:19 AM • Toastmaster... • Answered on Oct 01, 2020
I have a toastmaster TM-121CM 12 cup digital coffeemaker. The indicator dot on the start button is blinking and won't brew. It's supposed to be a steady dot. How do I get it to stop blinking?
sometimes they will be set up to blink and it is to let u know you that theres a problem so it will blink until its fixed or take the bottom off and disconnect the wire to it but i would just unplug it and then its got no power because you say it doent work any way. you will see when you open it up all the different gizmos and then trouble shoot. in reality if it didnt cost an arm and a leg i would probably buy a new one as they start breaking down and if its because of age then what will be next, good luck.
9/27/2019 5:56:59 AM • Toastmaster... • Answered on Sep 27, 2019
2answers
Is there a motor for a model 9a2 toastmaster heater?
Take the motor out. Disassemble it, clean the rotor shaft and bearings with rubbing alcohol and pipe brush. Add some 3 n 1 oil to the bearings and reassemble. Works like new.
9/8/2019 9:14:28 PM • Toastmaster... • Answered on Sep 08, 2019
2answers
Where can I buy a kneading blade for a Toastmaster
The Breadman Model TR888 uses the very same kning blade paddle as your Toastmaster Model 1185.
Click here:
http://www.directpartsandproducts.com/tr888-kneading-paddle-p-8818.html
Hope this helps!
5/24/2018 11:02:31 PM • Toastmaster... • Answered on May 24, 2018
Toastmaster (TMHP2) Electric Kettle Logo
Popular Tags
8 questions posted
Top Toastmaster Kitchen Appliances - Others Experts
NOEL
NOEL
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Toastmaster Kitchen Appliances - Others
Most Popular Question
metal in bottom kettle turn green
  • Kitchen Appliances - Others
