20 Most Recent
HP DeskJet 520 InkJet Printer Questions & Answers
I purchased a HP Deskjet
wallmart will tell you anything, they sold it, they're responsible for it. from personal experience, if it's been opened, it don't work. additionally, we're not responsible for supplying anything, we do it as a 'favour' and simply pass on the information to help you if at all possible.
anyway back to your request, the software you need is here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=59768#N187
just select your operating system from the list, click next then download and instal the software - instructions are also provided.
I cannot print a word document
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your word application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.othewise install the ms office word application again.
Can't get instuctions for my paper feed cleaning kit!
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case,
you will probably have to take the printer in for servicing..
Thanks
Thiru
HP 520 Desk Jet printing garbage
fot resolve this issue you should try that get a self test print ,( demo print) if it is good you have a software problem and also you should install the dirvers . if the demo test print is not good you have a hardware problem about carriage and ink system and you have to replace the carriage system.
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color.
If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
My printer cutting text from the right side when printing .HP deskjet 2050 J510
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
I have error 0xc19a0023 in my printer hp deskjet 3520.I replaced new cartridge but it isn't correct.What should I do?
1) Open the printer cover and wait till the carriage moves towards the middle.
2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer.
3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward.
4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab.
5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges.
6) Close the printer cover. Connect the power cord at the backside of the printer.
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
10/11/2018 10:24:24 AM •
HP DeskJet...
Answered
on Oct 11, 2018
I have installed an HP Deskjet 3520 as default
I have had this happen in windows operating system. It was caused by a corrupt user profile.
You can try control panel users accounts.
Try modifying the user account type like changing the permissions and windows should re save the user profile . then change it back to what it was.
or look at
https://neosmart.net/wiki/corrupt-user-profile/
