20 Most Recent
Friedrich QuietMaster RS10J10 Air Conditioner Questions & Answers
Split Unit Spitting water
Do you live in an area of high humidity? This could be your problem. The water that is coming off the evaporator and draining to the outside pan is building up and picked up by the condensor fan and consequently blown by the fan inside. If this is the problem the fix is to drill a hole in the pan to permit the water to drain from the pan. Be careful as to where the hole is drilled so as to not damage any component of the a/c. I would suggest at least a 1/4 inch drill bit be used to make the hole.
8/22/2011 8:14:29 PM •
Friedrich...
Answered
on Aug 22, 2011
THE COMPRESSOR AND COOLING WORKS
I would say the fan motor is not working you will need to take the casing off and look to see if the wires to the motor are off, or if the motor is frozen/stuck(will not freely rotate) Tim
5/29/2011 7:19:55 PM •
Friedrich...
Answered
on May 29, 2011
Where is the vent on my Friedrich AC unit? I
the fresh air vent open close tab should be located somewhere along the vent louvers look at the bottem of them starting from right to left its their use a flashlight to see it good luck ..let me know /joe/
8/26/2010 1:14:37 AM •
Friedrich...
Answered
on Aug 26, 2010
Exhaust/Fresh Air Vent
Hello there :
ok i'll explain it like this if you have the lever on exhaust it will be just circulating the air that is all ready in the room and if you have it on fresh it will be drawing the air from the outside ok hope this helpes you understand how that works please dont forget to rate my solution.
best regards
mike
(USN) RETIRED
4/6/2010 1:33:27 AM •
Friedrich...
Answered
on Apr 06, 2010
Unit Turns Off
Have you checked the breaker in the breaker box to see if it's tripped? Also check the amp rating on the air conditioner and the amp rating on the breaker the unit is plugged into, the breaker may be weak or not a high enough amps or rating for the unit it's trying to power.
7/28/2009 3:25:49 AM •
Friedrich...
Answered
on Jul 28, 2009
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
7/26/2009 10:40:44 PM •
Friedrich...
Answered
on Jul 26, 2009
