20 Most Recent Copystar Kyocera Taskalfa 181 Copier Questions & Answers
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Copystar Kyocera... | Answered on Oct 30, 2019
It is usually because you have the machine set up as A4 and the your documents or printer driver set to 81/2 X11(American letter size) size paper ,to override this ,got to the menu system button in the top left of the operation panel ,scroll down to printer setting in one of those menues you'll find A4/letter override turn it on and you'll get rid of the problem .
Copystar Kyocera... | Answered on Oct 07, 2019
Soo...Call for service
Copystar Kyocera... | Answered on Mar 14, 2019
Fuser error. Ensure that no paper is jammed in the fuser unit.Switch the machine off/on.
If fault does not clear call technician.
Copystar Kyocera... | Answered on Jan 20, 2014
change print driver, make sure you use kx driver and not xps driver, also under device settings make sure you change it to pcl xl.
Copystar Kyocera... | Answered on Dec 14, 2013
Fuser error try to reset it otherwise if it didnot work, change fuser unit
please unlock the 2 scanner lock on top left side of the machine. the lock will be in yellow colour and it will covered by red tape.
Copystar Kyocera... | Answered on Dec 04, 2013
if this were your problem it would be obvious the inner tray is in the middle of the machine there is a lever that lifts up as paper stacks up its probably stuck in raised position
Copystar Office... | Answered on Nov 14, 2019
This code is a high temperature in the fuser unit. The reset process is as follows, enter 1087-1087-163-print button-execute-print button then shut machine off when the message comes up on the display. The machine should clear the code and reboot, if the code returns you will need to contact a service company for further assistance. Hope this helps.
Copystar Office... | Answered on Sep 11, 2019
Press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Copystar Office... | Answered on Apr 27, 2019
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
/uploads/images/copystar-c2300-error-code-34884244-4-1.jpg
Copystar Office... | Answered on Mar 22, 2019
Bad Hard Drive
Copystar Office... | Answered on Mar 14, 2019
Paper jam in the paper cassette
There is still a jam inside the copier
Copystar Kyocera Taskalfa 181 Copier Logo
23 questions posted
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Copystar Office Equipment & Supplies
Most Popular Question
plz fix taskalfa 181 c6400 error
  • Office Equipment & Supplies
