20 Most Recent HP LaserJet 5550 Printer Questions & Answers
2answers
Hp 5550 dtn 10.00.00 supply memory erro
the chip is faulty on the black cartridge, change the black and it'll work, alternately you can out it diagnostic made and run without the cartridges being monitored
9/20/2022 6:47:59 AM • HP LaserJet 5550... • Answered on Sep 20, 2022
Hp 5550 card slot not initialised
power off/onhold menu button when memory count startsrelease when 3 light lit.select init disk
10/9/2021 9:01:12 PM • HP LaserJet 5550... • Answered on Oct 09, 2021
2answers
How to reseting hp laserjet printer ETB
Need HP Printer Support . Call Toll Free Phone Number - 877-690-9305 hp printer support -1-5y1xerifmav3c1grzoip5vgk-2-0.jpg HP Printer Support 877 690 9305 Call Us now get Printer Support
3/28/2018 4:19:31 PM • HP LaserJet 5550... • Answered on Mar 28, 2018
Hp 5550 service codes
communication error: upgrade your print driver and it should run better. Here is where to find print drivers. http://www8.hp.com/us/en/drivers.html
12/11/2017 12:58:00 PM • HP LaserJet 5550... • Answered on Dec 11, 2017
Error 0XC0000005 in HP Color Laserjet 5550dn printer
uninstall and reinstall your printer drivers. Best to upgrade to HP Universal Print Driver version 6.3. Post Script.
10/18/2016 5:48:32 AM • HP LaserJet 5550... • Answered on Oct 18, 2016
Hp color Laserjet printer 5550 printing very slow
Please check your paper tray adjustments and verify that the paper type for the tray is set to any type or plain (assuming you are printing on plain paper). In general, if the machine has reason to believe that there is a custom size or special type of media, it prints at half speed.
9/16/2016 1:30:18 PM • HP LaserJet 5550... • Answered on Sep 16, 2016
How to remove gray shadings in the background of my printouts for my printer hp color laserjet 5550?
Grey shading likely due to either bad black cartridge. Try a different cartridge first thing. After that, print a PQ quality test page from the control panel to see if they defect shows on all pages. If it does then you may have a bad transfer belt.
8/28/2016 6:05:37 PM • HP LaserJet 5550... • Answered on Aug 28, 2016
2answers
RFU load error
I have a printer HP Color Laser Jet 5550' i cont print when i on the perinter ther 59 er--co is come on printer screen and the printer can not work .waht sould i do it cont rest too plase
5/16/2016 6:36:21 PM • HP LaserJet 5550... • Answered on May 16, 2016
Where is the ETB motor?
2/18/2015 11:36:01 PM • HP LaserJet 5550... • Answered on Feb 18, 2015
Can you print on 200gsm in the hp5550
i think you may have difficulty printing on that paper, thickest recommended is actually 150gm. i would suggest if this stock is well bendable, give it a try, if it is very stiff - do not even bother, there is very torturous path on this printer and 180deg turn on 40mm (1 3/4") radius is not exactly easiest, later models of this printer were equipped with doors which allow print on transparencies and more stiff (thick) papers, if yours is from 2007/2008 - one of the first models - it may not have this doors. for further info go there: http://h20566.www2.hp.com/portal/site/hpsc/public/psi/manualsResults?sp4ts.oid=409994&ac.admitted=1423745430236.876444892.199480143 choose and download general reference, as i do not know more about your system - download and read both... hope this will help you - do not forget to vote...
2/12/2015 1:01:21 PM • HP LaserJet 5550... • Answered on Feb 12, 2015
200gsm what? Usually there's a setting for thicker papers, which slows down the fuser, so that the card gets heated right the way through and the toner will adhere better.
2/12/2015 12:57:16 PM • HP LaserJet 5550... • Answered on Feb 12, 2015
Bin full output paper remove standard
There are plastic flags in the output bin that may be stuck.
1/31/2015 2:47:32 PM • HP LaserJet 5550... • Answered on Jan 31, 2015
How do you resolve 59.30 error code on HP color laserjet 5550
finally i solve this problem hp colorlaserjet 5550 error 59.30 same with an error 59.40 ERROR this is occurred with the fuser motor during startup or not rotating. take the left cover off and replace the motor. hope this will help.
6/11/2014 3:28:00 PM • HP LaserJet 5550... • Answered on Jun 11, 2014
0answers
HP LaserJet 5550 Printer Logo
172 questions posted
Ben Johnson
Marvin
Marvin
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
printer froze download message
  • Office Equipment & Supplies
