20 Most Recent HP LaserJet 2605dn Printer Questions & Answers
Hi there can you help with my HP2605? Since i
click on the alignment button and have the machine automatically start the realignment process it is not color realignment but printer head alignment that is the problem
5/4/2017 4:27:46 AM • HP LaserJet... • Answered on May 04, 2017
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps: 1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
11/26/2014 2:26:29 PM • HP LaserJet... • Answered on Nov 26, 2014
Hp laser jet 2605dn give a error 10.0000
Any 10 errors are related to cartridges and the memory chips on them. If you just changed a cartridge then it is possible that it is defective. Try putting the old cartridge back in. Also ensure that the cartridges are all seated fully and that the front door closes properly as this can trigger the error as well.
10/10/2014 5:41:54 AM • HP LaserJet... • Answered on Oct 10, 2014
No display
When you plug it in and turn it on does it make any noises at all?
8/15/2014 2:11:17 PM • HP LaserJet... • Answered on Aug 15, 2014
Hewlett Packard Laserjet 2605dn Printer: Error 79 after firmware update
HP has now admitted their firmware update causes an irreversible corruption in the formatter board. It is hard to get them to do this, but I understand they will repair at no cost if they can determine that you did install this update.
3/18/2014 8:02:28 PM • HP LaserJet... • Answered on Mar 18, 2014
0answers
Serial number hp 2605dn
print off a configuration report and will be on there at the top left corner
10/22/2013 10:39:50 PM • HP LaserJet... • Answered on Oct 22, 2013
Printer was on a network with network settings. I
Are you trying to use it on your home network?
9/11/2013 3:58:35 PM • HP LaserJet... • Answered on Sep 11, 2013
0answers
Color fading magenta
magenta is the lowest color inside, thus the magenta scanner assembly is either failing or just plain dirty. repair time should be in the 1+1/2 to 2 hour range.
12/25/2012 7:38:00 AM • HP LaserJet... • Answered on Dec 25, 2012
Magenta cartrage is 25 % full but will not print
try printing the Supplies Status Page and the DEMO page. if no magenta on either page, then it sounds like the scanner assembly is dirty. this is the lowest position scanner; it can be partially seen from inside the cartridge cavity. Typically a 1-1/2 (ish) hour repair.
12/25/2012 7:10:53 AM • HP LaserJet... • Answered on Dec 25, 2012
Spitting Ink
For the price of ink i would consider throwing it away and buying a new printer. This can be cleaned if the print heads are not damaged but they cannot be replaced like some Canon models. I would consider a Canon or a Brother printer as the ink is cheaper and you can find great generic inks online at lower prices.
10/19/2012 1:46:14 PM • HP LaserJet... • Answered on Oct 19, 2012
102 questions posted
Clive
Clive
Ben Johnson
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hewlett packard laserjet 2605dn printer
  • Office Equipment & Supplies
