20 Most Recent
Shure T2 / PG58 Professional Microphone Questions & Answers
Mic won't power on. Battery is not the
It could be many different things. An experienced technician would need to look over the entire transmitter to diagnose what is wrong. The following company might be able to repair it: www.deltaaudio.biz
How to sync shire pg4 and pg58
First, make certain they are on the same frequency band. Then, simply set them to the same channel. That's it. It's that simple.
We're using 30 Shure microphones,
What is happening to the switches, specifically? Our shop has fixed hundreds of T2s but rarely a switch problem. We'd guess they're getting gunked up. Send a photo to Delta Audio and we'll try to advise. Good luck.
My Shure T2 has a damaged + terminal for the
1) Pop off the switch actuators.
2) Remove the cartridge on top.
3) Remove the c-clip that holds the circuit board int the handle (this is where the cartridge used to be)
4) Slide out the circuit board.
Older style 58 wirless - dead - was intermittant
The upper assembly unscrews at the windscreen. Carefully - as there are shock mount parts and all matter of trouble hiding there. Guess you can't break it any worse. If you get it all together again, the more likely cause of being intermittent is the on/off switch.
Shure T2 SM58 intermittent transmit
Two screws on the back of the battery casing, then prise out the battery tray (it's a detachable moulded tray in the mic body) using a small screwdriver in the slot near the power button. Under the threads of the battery cover is screw which holds in the PCB, unscrew this.
Take the full mic head off (not just the ball, but an inch further down with the capsule in it), and remove the circlip inside.
The PCB then slides out towards the head end of the mic.
Mic fell down it can switch on but no audio
Do these have the interchangeable heads?
Unscrew the head and check the raised pins, these often become dirty and the connection can become poor over time, especially with a knock.
