20 Most Recent Motorola T6510 XLR Talkabout Two-Way Radios : Questions & Answers
http://shop.giantintl.com/Manuals.asp?offset=30
Motorola T6510... • Answered on Dec 17, 2015
This radio is one of the TalkAbout radios which uses FRS (family radio service) frequencies designed for use in the United States. The frequencies are preset in the radio and it cannot be reprogrammed to any other frequencies. Here is a link to the user guide (use the pulldown to select your model) http://shop.giantintl.com/Manuals.asp Best regards.
Motorola T6510... • Answered on Jan 06, 2015
Replacement parts were never made available for the TalkAbout radios (other than the higher wattage TalkAbout Distance and Distance DPS). Your options are replace the radios, or watch for used radios for parts on ebay and other similar websites. Best regards.
Motorola T6510... • Answered on Jul 21, 2014
Contact Motorola Solutions (https://portal.motorolasolutions.com/Support/US-EN?WT.mc_id=support)
Motorola T6510... • Answered on Jul 18, 2014
these are one-way radios. no service, no spareparts. just trough away and buy new
Motorola T6510... • Answered on Jun 11, 2014
Check your battery contacts, both on the radio and the charger. Clean with a pencil eraser if needed. It is possible you are not getting good contact. If both radios are not getting charged in a dual well charger, you may have a problem with either the wall adapter or the base. (Assuming your batteries are good.) Wall adapters burn out over time, somewhat like a light bulb.
Replacements are available at the Motorola online store. http://www.store.motorola.com/2-Way-Radio-Rechargeable-Battery-Upgrade/dp/B003H0FUD2?ie=UTF8&id=2-Way%20Radio%20Rechargeable%20Battery%20Upgrade&field_availability=-1&field_launch-date=-1y&field_browse=2265964011&searchSize=12&searchPage=1&searchNodeID=2265964011&refinementHistory=brandtextbin%2Csubjectbin%2Ccolor_map%2Cprice%2Csize_name&searchRank=salesrank This kit contains a pair of new batteries and a complete charger.
Best regards.
Motorola T6510... • Answered on Nov 08, 2010
If you are referring to the 'roger beep' you could get following the release of the PTT. See the instructions near the bottom of page 25 of the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
If you are talking about the beeps made when you press any of the keys on the keypad, these cannot be shut off. However, you can eliminate some of them by locking the keypad, page 20.
Best regards.
Motorola T6510... • Answered on Nov 05, 2010
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf You will find programming instructions beginning on pg 17.
Best regards.
Motorola T6510... • Answered on Oct 21, 2010
There are two features which cause the radio to make a tone or beep, before or following a transmission: Talk Confirmation Tones (aka Roger Beep) and Call Tones.
On the T6510 radio you would hold in the + (plus) button while turning the radio on, to turn ON the roger beep. To turn it OFF you would hold in the - (minus) button while turning the radio on.
Call Tones are a little more detailed explanation. You can find directions for both in the user guide on page 25: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
Motorola T6510... • Answered on Oct 02, 2010
The radio you are describing is a HT1250 VHF 5 watt with display and full keypad. This radio cannot be reset by the user. It is a dealer programmable radio requiring a RIB (radio interface box), cable, and Motorola proprietary software. Your local Motorola dealer should have a subscription to this software and be able to program the radio to your frequencies.
Here is a link to the manual: http://www.connectingyou.com/media/HT1250.pdf
Best regards.
Motorola T6510... • Answered on May 21, 2010
Aquí hay un enlace a la guía del usuario: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
La frecuencia, el código eliminador de interferencia, y el filtro de Qt, deben coincidir entre sí. Para el funcionamiento básico establecer el código de Qt y filtrar a cero (apagado).
Un cordial saludo.
Motorola T6510... • Answered on Apr 29, 2010
You will find both Call Tones and Talk Confirmation (Roger) Tones on page 25, with a full explanation of turning them on and off.
Best regards.
Motorola T6510... • Answered on Nov 28, 2009
8 hours first time, and 4 hours after that.
Motorola T6510... • Answered on Nov 23, 2009
I do believe it is a 9 volt charger. Look under the battery cover and it will say how many volts. It is probably 9 volts. Just have to find a 9 volt charger with the same plug as you have. Or contact Motorola for new one. Possibly E-bay
Motorola T6510 FRS walkie talkie with charger
http://shop.ebay.com/items/_W0QQ_nkwZT6510Q20chargerQQ_armrsZ1QQ_fromZR40QQ_mdoZ
$1.04
Motorola T6510... • Answered on May 13, 2009
Motorola T6510 XLR Talkabout Two-Way Radios : Logo
Popular Tags
26 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Sheldon Dedek
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
set
  • Radio Communications
