20 Most Recent Dell 1702FP UltraSharp 17" TFT LCD Flatscreen Monitor Questions & Answers
The width of PC screen has suddenley widened, so that data is not viewable, how to I readjust it?.....
Right click on desktop and click screen resolution. Then select the recommended resolution for your monitor and click apply then OK. This sholud solve your problem.
6/9/2014 5:52:44 AM • Dell 1702FP... • Answered on Jun 09, 2014
Cant power on unit
Please verify that you do have 14vdc coming out of the AC adapter, the problem can also be at the DC input jack due to crack solder joints. If you do get the power light on the monitor to come on but the screen is black, then the problem can be in the inverter board. http://www.lcdrepair.us/1702inverter1900.html
http://s807.photobucket.com/home/budm/allalbums
4/27/2010 10:38:49 PM • Dell 1702FP... • Answered on Apr 27, 2010
There is a black line and see through pink bar on my monitor
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
also check you warenty its usually 3 years
4/17/2010 7:55:46 AM • Dell 1702FP... • Answered on Apr 17, 2010
2answers
Monitor screen is black and power button flashes
MAY BE YOUR PICTURE TUBE IS DAMAGE OR MAY BE YOUR DISPLAY CARD IS DAMAGE.
12/10/2009 4:46:13 AM • Dell 1702FP... • Answered on Dec 10, 2009
I have a flat screen monitor. when i power up the
This model has a know problem with parts called capacitors shorting out and causing the flashing that you have. If you can solder then you should be able to do the repair yourself. If you go to our web site at:
www.ccl-la.com and click on the monitor repair section I will post a step by step guide to the repair for you. You will need to replace 2 capacitors and yo should be back running again. Check after 12/09/09 at 2:00pm and the guide should be posted.
I hope this helps, f so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
12/9/2009 5:03:31 PM • Dell 1702FP... • Answered on Dec 09, 2009
2answers
My DELL flatcreen just went blank and is now
Check and make sure your connections on the back of the PC are snug...and make sure you have a good connection at the back of the monitor.
Flashing light...is loss of signal.
Good Luck,
Mike
11/6/2009 12:11:46 AM • Dell 1702FP... • Answered on Nov 06, 2009
Monitor comes on and displays for a second then
New monitor? Does old monitor still work? Did the monitor ever work? did the computer ever work? is power light on computer on? is power light on monitor still on?
10/15/2009 4:47:16 AM • Dell 1702FP... • Answered on Oct 15, 2009
How do i zoom my screen in and out on my computer monitor
built in windows on screen magnifying glass: https://support.microsoft.com/en-us/help/11542/windows-use-magnifier a more advanced version https://technet.microsoft.com/en-us/sysinternals/zoomit.aspx
8/22/2016 5:23:04 PM • Dell UltraSharp... • Answered on Aug 22, 2016
DELL MONITOR 2405FPW,HOW TO ADD TO MY DEVIVCES
Try to use another power cable, or another power socket . If won't on, maybe you have problem with the monitor. Have you pressed the power switch?
6/13/2015 3:19:50 AM • Dell UltraSharp... • Answered on Jun 13, 2015
Windows 7 only recognizes my dell 1905fp monitor
You need to remove the standard windows monitor driver in the device manager and reinstall the monitor driver. Search in google and download the driver and install it. Good hunting.
12/7/2014 3:33:25 PM • Dell UltraSharp... • Answered on Dec 07, 2014
Which driver can I take for my monitor?
Yes, you can use the 'Generic' option in Windows, assuming you are using Windows Bruno
8/6/2014 7:54:25 AM • Dell UltraSharp... • Answered on Aug 06, 2014
0answers
0answers
Broken screen display , how to fix the screen ?
This is a problem that takes a skilled technician to repair both monitors and PSU's are not to be tampered with by the untrained. It may be possible to replace the screen and there are many places to be found that will provide this service but the cost of the repair might be prohibitive.This link will show you a video if you feel up to the jobhttp://www.youtube.com/watch?v=9Q6_TgNJvQwA monitor may have an electrical charge still in its capacitors so make sure you are properly earthed and all power plugs are removed. A second hand replacement might be a safer option.
10/7/2012 1:09:01 PM • Dell UltraSharp... • Answered on Oct 07, 2012
Computers & Internet Logo
11 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
UltraSharp Dell
  • UltraSharp Dell
Most Popular Question
width pc screen suddenley widened data
  • Computers & Internet
