20 Most Recent Dell E152FPb 15" TFT LCD Flat Panel Monitor Questions & Answers
the resalution is set to hight for the old monitor recaize the only way to fix it is to put hte old monitor on and change the resolution to a different size like 1080 adn then put the new monitor on and it should have fixed it. for some monitors will onluy go so high and if the res is over that hten the month will just not desplay anything but a blue screen
Dell E152FPb 15"... | Answered on Sep 17, 2018
Simply connect via VGA, DVI, or HDMI to video card.
Dell E152FPb 15"... | Answered on Aug 26, 2012
On E152fpb dell only replace all driver transistor the c5706 or c5707 this 2 types of transistor is not desame one is PNP & NPN so you must be careful of replacing component maybe it will help you
Dell E152FPb 15"... | Answered on Jun 14, 2012
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Dell E152FPb 15"... | Answered on Nov 10, 2010
It is standby mode, no signal, It is possible that your computer is not POSTing.
Connect your screen to another computer/laptop, just to make sure, which component is not working. Either the Screen or the Computer.
Make sure the DVI/VGA cable is firmly connected as well as RAM modules and Graphics Card.
Please take the time to rate my expertise.
Thanks
Dell E152FPb 15"... | Answered on Nov 03, 2010
borkoven, Will E152FPD act same way when you reconnect it to a windows XP computer? 12fixlouie
Dell E152FPb 15"... | Answered on Oct 25, 2010
Check the plug for a fuse, check to see if any power is getting to the Power adapter ( is there a little light on it?)
Is the plug or socket damaged ?
You MAY be able to buy a replacement, but i could not find any, only laptop replacements.
Dell may be able to get you a replacement, contact them on there support page
Dell E152FPb 15"... | Answered on Aug 25, 2010
dhowie, Monitor will need work done to internal "switch-mode-power-supply"/"CCFL inverter supply board. possible bad electrolytic filter capacitors or thermally intermittant component soldering on printed citcuit board. Your CCFL back-lit LCD display no different than any other brand in it's basic design and operation. Spend an hour in my fixya profile reading about black screen and blank n black screen stuff. Then you will know what you will do or not do to solve V71LCD problem. Follow the links to other sites for more info here on fixya and elsewhere. I will check for response from you at this same posting later.
12fixlouie
Dell E152FPb 15"... | Answered on Mar 12, 2010
Check the four transistors (c5707/5706) in the inverter section for shorts, board looks like this? http://www.lcdrepair.us/e152-e153fpb-inverter-power.html
Dell E152FPb 15"... | Answered on Feb 21, 2010
If it is possible to boot this machine in safemode, you can boot it and change the resolution to low mode, and reboot the machine
Dell E152FPb 15"... | Answered on Oct 14, 2009
No It seems to be dry solder joints on the Invertor / powerboard.
Samir
Dell E152FPb 15"... | Answered on Nov 05, 2008
Lots of software out there will join video segments. Question is, what type? AVI, MPG, WMV etc.?
One of the best (imho) is Virtualdub which also happens to be free. Here's a start for your learning
experience:
http://www.videohelp.com/guides/category/how-to-cut-join-edit-avi-divx-xvid-wmv-asf-5;19#5;19
Also check the Guides here too:
http://www.doom9.org/
Dell Computers &... | Answered 3 days ago
case size what? (this tell what mobo is inside) yeah.
OS is what window 10?
what is in your hand USB? device, cant guess that.
do all ports fail?
is USB 2 and 3 ports all turned on IN BIOS F2 pages.
does keyboard USB fail on any USB ports
does it fail in BIOS windows only or that and BIOS screens too. if fails in BIOS too, that means the ports some are tuned off in BIOS.
try asking dell
Dell Computers &... | Answered on Dec 01, 2020
An out of date BIOS can cause this error code. From Dell Drivers and Downloads website download and Install the latest BIOS. If prompts you to update the previous version, you must first update the same and then flash to the latest version of BIOS.
It alway zs helps to know the model number. Witht that information, you should be able to find the specifications at the Dell support site. It would simply tell you in a specs sheet. I guess you could download HWinfo, a handy freeware program and check informaiton about components there. There is of course the option to download the user manual.
Dell Computers &... | Answered on Nov 26, 2020
Dell E152FPb 15" TFT LCD Flat Panel Monitor Logo
23 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
  • Dell Computers & Internet
Most Popular Question
after changing c5707 c5706 transistors
  • Computers & Internet
