20 Most Recent Sony Handycam DCR-DVD505 DVD Camcorder Questions & Answers
Why does LCD screen not respond to touch
Common problem. There is a flexible cable that goes from inside the body to the flip out LCD screen. More than likely, this cable needs to be replaced. Time for Professional service. We can help! Contact Us at AVRepair com
4/17/2019 2:45:12 PM • Sony Handycam... • Answered on Apr 17, 2019
0answers
2answers
Can't import video into Windows Movie Maker.
Recommend you to try this exciting program ,it can convert VOB. to any popular format as you like ,such as you could use this program to transfer the file to avi or wmv in order to edit this fim into windows Movie maker.
12/13/2012 2:22:39 AM • Sony Handycam... • Answered on Dec 13, 2012
USB drivers won't install
2/18/2011 4:19:58 PM • Sony Handycam... • Answered on Feb 18, 2011
0answers
WHAT IS THE EASIEST WAY TO DOWNLOAD FEW 30MIN. DVD
for sony if you do not have a disk that came with the camera you do not need one ...but here I will link you to the support site and see if there is any download for your cam Usually if it has a Firewire connection cable it only need a manager to operate the download...
If the camera has a memory card ..the easiest way is to store the footage on the card and use it directly on the computer 's card reader..anyway..another way is to use a dvd in the camera directly ...finalize the disk to be readable and use it to get the files into computer and there copy all and paste on the hard disk in any location you have space ..and after that edit it like you please...Even without having a very fancy program you can edit in windows movie maker available in any windows since XP..
Here is the support site..
http://esupport.sony.com/US/perl/model-home.pl?mdl=DCRDVD505&LOC=3
11/6/2010 4:17:45 PM • Sony Handycam... • Answered on Nov 06, 2010
I owned dcr-dvd505. i lost my cd-rom thats why i
Sony say the drivers for this camera are already included in Windows operating systems. You can download other drivers and software from this Sony support site:
LINK
10/18/2010 11:25:15 AM • Sony Handycam... • Answered on Oct 18, 2010
Buttons on the LCD screen
The most likely cause for this is a damaged or defective flexible ribbon connector between the LCD and the camera body and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9/3/2010 5:57:26 PM • Sony Handycam... • Answered on Sep 03, 2010
My SONY handycam 505 touch screen does not
Unfortunately this fault might need more attention as the set must be opened out.
Try to remove battery and reset, dry out by keeping the set warm, clean the display panel of any dirt.
if this wont work the camcorder must be openend and checked on the diplay panel if there is any line stips, the flexible lines being cut or broken. remove and fix connectors, if set was not used for long time put the set ON for several hours.
If this wont work you must contact Sony service to confirm if the display control board is faulty
8/23/2010 6:39:56 PM • Sony Handycam... • Answered on Aug 23, 2010
Was in mexico and video
Hi V.
Try first removing internal battery to reset camcorder. This is first necessary step in troubleshooting.
The lens is probably dirty and the camcorder does not detect that there is the correct media inside.
Try using a lens cleaner disk or cleaning the lens directly, using extra-soft QTips and isopropyl alcohol or cleaning solution.
Lens cleaning operation may affect your warranty status, before proceeding call manufacturer.
Also, even if very rarely, the direct cleaning may damage the camcorder if done with too much strenght or in the wrong way. Do it at your risk.
Ginko.
8/11/2010 5:00:58 PM • Sony Handycam... • Answered on Aug 11, 2010
My camera was stored for a few months, could not
hi
it should be changed
its better to repair by an expert
7/25/2010 7:07:38 PM • Sony Handycam... • Answered on Jul 25, 2010
I'm trying to find the
Click Sony Support link, select Windows OS in drop down list that you are running in computer to download related driver/ update.
However, Picture Package Software disc is also available in Sony Accessories Store for $29.95 under following part number.
266675301 PICTURE PACKAGE SOFTWARE
Hope these info will help you.
Thanks.
7/7/2010 1:18:39 AM • Sony Handycam... • Answered on Jul 07, 2010
Touch Screen doesn't work at all. Can't use camera. How do we fix
Hi. Just a tip, try to do a calibration on the touchscreen. If it still does not work, there is a problem with your touchscreen itself. Hope this help. Goodluck
6/5/2010 6:20:01 PM • Sony Handycam... • Answered on Jun 05, 2010
2answers
Window movie maker, does not recognize my dvd camcorder
the issue is that your camera exports this movies in a format that the movie-maker do not recognize ...so ..what you really meed it is a movie converter to convert the files you download from the camera into such files that are seen by the movie maker..
http://www.any-video-converter.com/products/for_video_free/
this is a converter like I mentioned...it is a free universal one ..but on the net there are better instruments also...try it ..if it works its fine ..if it do not see your exported files to convert them in avi or mpeg4 ...just look on the internet for another one that does a similar job ..
good luck ..and do not forget to rate ..
1/20/2010 9:23:08 AM • Sony Handycam... • Answered on Jan 20, 2010
Trying to get my Sony handycam hooked up to use as
You will have to download the driver for your camcorder. You can use DVdriver software from http://www.trackercam.com
Regards, Joe PS kindly rate my answer. Thank you.
1/17/2010 9:22:45 PM • Sony Handycam... • Answered on Jan 17, 2010
Sony Handycam DCR-DVD505 DVD Camcorder Logo
47 questions posted
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
camera stored few months could not
  • Video Cameras
