20 Most Recent
Dell Powered Subwoofer Set A425 Computer Speaker Set W8037 Questions & Answers
How do i hook up a Dell A425 subwoofer to a
describing a pin-out to people who are not electrical engineers is like explaining to someone how to build a clock when they asked what time it is.
Looking at the orange VGA connector on the back, which two holes have the wires that go to the two sides of speaker wire for the subwoofer? Do i have to do anything else to make it just work like a simple speaker and just be controlled by the amplifier (receiver)?
Like seriously, am I asking it simply enough? Which two holes in the orange female vga plug on the back of the subwoofer correspond to the + and - speaker wires that go to the "subwoofer" hookup on the back of my stereo? I don't care about what each pin does because those words don't mean anything. I don't understand. WHICH. TWO. WIRES.
and then is there anything else i have to do like stick a paperclip from one hole to another and hope it doesn't explode?
Also, I don't know what the numbers of the holes are. so saying "pin 9" or whatever is meaningless without a diagram.
thank you for my ted talk.
Schematic Diagram for A425 amplifier
Did you ask Dell for help? Just don't hold your breath - they would rather you get a new one from them but U can try. If nothing, check it out on Google - might get lucky!
I need the driver for it, i have no sound
Anonymous,
There are no drivers for the A425 speakers. Make sure the power cable is attached to the speakers as well as the speakers plugged into the correct jacks. If your speakers are plugged in and powered on and u still have no sound; check to make sure the sound card drivers are installed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
A425 subwoofer, more bass? wires came off, no bass managment.
I wouldn't cross wires or leave one disconnected. Can you solder the wires back on the the control knob? Did you feel the subwoofer cone to see if it's working at all? I would guess the wire you didn't connect, is the subwoofer wire. Try putting it back to original cofiguration and solder the wires in place.
Worked great for years. Now, won't turn on.
Next step would be to check for power from the wall wart (external power supply). Note the output voltage indicated on the power supply, then check for that approximate voltage with a multimeter.
A replacement power supply can be found at most electronics retailers. Make sure the polarity matches, ie positive tip or negative tip, and the plug must match dimensionally. Make sure a replacement can supply the current that the original did (rated in milliamps - MA, or amps A). Ideally an exact replacement would be best if that is the issue. Be careful, and don't crack open that power supply!
Speakers not working since windows 7 installed
Hi, click on the "Start Button," in the (right pane) Control Panel, next in the category listings, select Hardware and Sound, open, and click on the "Manage Sound Devices." The Sound window will open; click on the "Playback" button, there should be a Speakers Icon, click on it, look below to find the "Properties button, click to open the next window. In the next window there will be (4) four buttons "General, Level... First click on the "General" button, in the top of the window there will be a "Driver" button, click on that button to open. Select to "Update Driver," just click on it, the Drivers will be updated for you. Next you can go back and press the other areas, Speaker Level etc... Next if you have a "MIC" do the same for the Microphone as you done for (Speakers) in the [Recording] category. Note: "Remember to click on the "Apply and OK buttons afterward to make sure the changes take effect. "Restart the computer to finalize the changes." "Rate the solution on it helpfulness, its away of letting me know if you resolved the the problem or you need further assistance, thank you."
My subwoofer and speakers wont draw power when i
The Altec Lansing A425 doesn't appear to have a fuse. Check for a circuit breaker on any surge protectors it might be plugged in to and make sure they haven't been tripped. Confirm that the power cord is firmly plugged in. Additionally, you could check the wall transformer with a multimeter to make sure it is providing the correct voltage needed by the speakers. Check the back of the subwoofer for a hidden power switch. If everything is plugged in and turned on, but you still don't have power, you will either need to open the device up and troubleshoot it or replace it.
Can i hook a sub woofer up to m-audio av40s
odwalxo, you can't add a subwoofer because the only output you have on those m audio speakers is for the "other speaker of the set via regular speaker wires". Everything else it's just inputs.
Internal Monitor speakers
Have you plugged its connection to your sound card on the pc? Check the connection again. it will help you.
Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
