20 Most Recent Sony Bravia 36 40 42 46 50 52 55 LCD Compatible Articulating TV Wall Mount Bracket With Free 10FT Male To Male HDMI Cable Adjustable Tilting Swiveling Wall Mount Bracket for LCD LED Plasma 3255 Inch Flat Screen Panels Questions & Answers
Kdl 40ex400 logo come own then color bars
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
12/15/2014 6:05:28 PM • Sony Bravia 36... • Answered on Dec 15, 2014
The screen is grey has something gone out in the tv
how many hours do you have on the tv
10/16/2014 11:23:42 PM • Sony Bravia 36... • Answered on Oct 16, 2014
My Sony KDL-42EX440 will not turn on
Have you tried to do a "reset" ALL modern electronic items often get "locked up" and unplugging them from the wall will often get them going again. Unplug for at LEAST 30 seconds--then try again. If this does not help--the SMPS board may have failed on you. A good repair shop may be able to repair the board instead of replace it.
5/8/2014 12:07:25 AM • Sony Bravia 36... • Answered on May 08, 2014
The word debug is on the screen. how do i take it off?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
3/1/2014 3:41:23 AM • Sony Bravia 36... • Answered on Mar 01, 2014
How to connect an older sound system to my Samsung smart TV.
Hi, Yes, please start with attempting to plug the sound system input into the appropriate inputs on your smart tv and then check the sound of various channels on your tv. If this does not work, please reference the manual for the sound system in order to get your sound working. And lastly, if that doesn't work, I would suggest working with your local Geeksquad/Bestbuy via a home service. Thank you.
11/24/2022 12:05:14 AM • Sony Televison &... • Answered on Nov 24, 2022
My Sony STR-DN850 IR will not work on receiver
1. Check your receiver's input: If you're having trouble getting your Sony STR-DN850 to play nice with your receiver, the first thing you should do is check the receiver's input. Make sure that the receiver is set to the correct input for the Sony STR-DN850. If you're not sure, consult your receiver's manual. 2. Check your Sony STR-DN850's output: Next, you'll want to check the Sony STR-DN850's output. There are a few things you can check here. First, make sure that the Sony STR-DN850 is set to output audio to your receiver. You can do this by going into the Sony STR-DN850's menu and checking the "Audio Out" setting. Second, make sure that the Sony STR-DN850 is outputting audio in the correct format. If you're not sure, consult your Sony STR-DN850's manual. 3. Try a different receiver: If you're still having trouble, you may want to try a different receiver. Sometimes, different receivers can play nicer with the Sony STR-DN850 than others. If you have a friend or family member with a receiver, see if you can borrow it for a few days to see if it makes a difference. 4. Check your receiver's remote: Finally, if you're still having trouble, you may want to check your receiver's remote. Sometimes, the remote can be the culprit when it comes to receiver/Sony STR-DN850 compatibility issues. Make sure that the remote is set to the correct input for the Sony STR-DN850 and that all the buttons are functioning properly. If you're still having trouble, you may need to consult your receiver's manual.
11/22/2022 4:48:21 PM • Sony Televison &... • Answered on Nov 22, 2022
Sony TV XBR-43X800G solarized picture, how to fix
If you're seeing a solarized picture on your Sony TV XBR-43X800G, there are a few things that could be causing the issue. Here's how to fix it. First, check the input source. If you're using an HDMI cable, try switching to a different input. If you're using a component cable, make sure it's securely connected to the TV. If the input source isn't the issue, try resetting the TV. To do this, unplug the TV from the power outlet and then plug it back in. Once the TV is back on, go to the Settings menu and select Picture. Scroll down to Picture Mode and select Standard. If you're still seeing a solarized picture, there may be an issue with the TV itself. In this case, you'll need to contact Sony customer support for assistance.
11/22/2022 4:48:01 PM • Sony Televison &... • Answered on Nov 22, 2022
2answers
My Sony VCR will not accept a tape and displays 71101 as the error code.
Hi John, I searched under "error code 71101 sony VCR" you'll get quite a few hits including fixya but there are several others which could be worth a look.
11/22/2022 4:47:07 PM • Sony Televison &... • Answered on Nov 22, 2022
How to fix tv with constant blinking green and orange lights and tv doesn't come on
How to fix a tv with constant blinking green and orange lights: If your TV has been constantly blinking green and orange lights, it is likely that there is a problem with the power supply. The first thing you need to do is to check the power cord and make sure that it is properly plugged into the outlet. If the power cord is not the problem, then you need to check the fuse box and make sure that the fuse is not blown. If the fuse is not the problem, then you need to check the power supply itself. If the power supply is the problem, then you will need to replace it. How to fix tv with tv doesn't come on when plugged in: If your TV doesn't come on when plugged in, the first thing you need to do is to check the power cord and make sure that it is properly plugged into the outlet. If the power cord is not the problem, then you need to check the fuse box and make sure that the fuse is not blown. If the fuse is not the problem, then you need to check the power supply itself. If the power supply is the problem, then you will need to replace it.
11/22/2022 3:15:41 AM • Sony Televison &... • Answered on Nov 22, 2022
Sony g14q1 sound with highly noise on RF signal
1. Sony g14q1 sound with highly noise on RF signal: If you're experiencing issues with your Sony g14q1 sound system, it could be due to a noisy RF signal. Here's what you can do to fix the problem and prevent it from happening again. 2. The problem and how to fix it: The problem with the Sony g14q1 sound system is that it produces a high-pitched noise when an RF signal is present. This can be annoying and make it difficult to enjoy your music. To fix the problem, you can try a few things. First, make sure that you're using the correct audio cables. If you're using an HDMI cable, try a different one. Sometimes, the problem can be caused by a faulty cable. If that doesn't work, you can try turning off the Dolby Digital Plus feature. This feature can sometimes cause interference with the RF signal. To do this, go to the Settings menu and select "Sound." Then, scroll down to the "Dolby Digital Plus" setting and turn it off. If you're still having issues, you can try moving the receiver to a different location. Sometimes, the problem can be caused by interference from other electronic devices. So, if you move the receiver away from those devices, it might help to reduce the noise. 3. Sony's response to the problem: Sony has acknowledged the problem and is working on a fix. In the meantime, they've released a statement saying that they're "aware of the situation and are investigating."
11/22/2022 3:07:53 AM • Sony Televison &... • Answered on Nov 22, 2022
My sony KDL "46vl160" sound is out of sync
1. Check your TV's audio settings: If you're experiencing audio issues with your Sony TV, the first thing you should do is check the audio settings. Make sure that the TV is set to output audio to the correct source. For example, if you're using an HDMI cable to connect to a sound bar, make sure that the TV is set to output audio to the sound bar. If you're using a receiver, make sure that the TV is set to output audio to the receiver. 2. Try a different HDMI cable: If you're using an HDMI cable to connect your TV to a sound bar or receiver, try using a different HDMI cable. Sometimes, the cable can be the issue. 3. Check your sound bar's audio settings: If you're using a sound bar, make sure that the sound bar is set to the correct audio input. For example, if you're using an HDMI cable to connect the TV to the sound bar, make sure that the sound bar is set to the HDMI input. 4. Check your receiver's audio settings: If you're using a receiver, make sure that the receiver is set to the correct audio input. For example, if you're using an HDMI cable to connect the TV to the receiver, make sure that the receiver is set to the HDMI input. 5. Try a different audio input: If you're using an HDMI cable to connect your TV to a sound bar or receiver, try using a different audio input. For example, if you're using an HDMI cable to connect the TV to the sound bar, try connecting the TV to the receiver using an optical cable. 6. Restart your TV: If you're still experiencing audio issues, try restarting your TV. Sometimes, this can fix the issue.
11/22/2022 1:49:52 AM • Sony Televison &... • Answered on Nov 22, 2022
Manual for sony rm-ed007 where to get
https://www.servicemanuals.net/en/sony-service-manuals
11/21/2022 2:53:45 AM • Sony Televison &... • Answered on Nov 21, 2022
3answers
7 time blinks tv sony kd-65x8500f
The 7 blinks on your TV is letting you know then that there is an error with the temperature of your TV or the sensor is not working or your TV is overheating. Or there is is an issue with the KD board or the GD board or an audio error.
11/16/2022 4:31:14 PM • Sony Televison &... • Answered on Nov 16, 2022
My Sony PSP won't play discs. Is it finally dead, or is it a simple fix?
It might now of have stopped working on you guys and is no longer working anymore too and someone had sold you a bad playstation portable unit.Or you can buy another one from a reputable places like JJ games and DKOldies and East Starland games. download-undefined-undefined-0_3.png
11/14/2022 8:58:43 AM • Sony Televison &... • Answered on Nov 14, 2022
I have a Sony 55 inch kdl-55hx800 and the hdmi and rca ports quit working what should I do to fix it?
Hi, please schedule a home appointment with geeksquad/bestbuy in order to help replace your tv ports. You might also call Sony to see if they can recommend any vendors for the repair. Thank you.
11/10/2022 2:30:17 AM • Sony Televison &... • Answered on Nov 10, 2022
I have blurry lines on my Sony XBR75X900E TV.
Reset your TV to factory settings or change the sources and check the video cables or the software needs to be updated or there could be a problem with the TV screen it's self and the LCD.
11/8/2022 9:38:22 AM • Sony Televison &... • Answered on Nov 08, 2022
Sony Bravia 36 40 42 46 50 52 55 LCD Compatible Articulating TV Wall Mount Bracket With Free 10FT Male To Male HDMI Cable Adjustable Tilting Swiveling Wall Mount Bracket for LCD LED Plasma 3255 Inch Flat Screen Panels Logo
14 questions posted
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
kdl 40ex400 logo come own color bars
  • Televison & Video
