20 Most Recent Maytag MAV6200 Top Load Washer Questions & Answers
Transmission is most likely bad.
Maytag MAV6200... | Answered on Sep 05, 2017
Check the cold water side of the water valve for a plugged screen where the water hose attaches to the washing machine. If there is debris in it you can carefully remove the screen and clean it.Make sure to put the screen back in or you could have more trouble sown the line. If this is not the problem more information is required.
Maytag MAV6200... | Answered on Jan 29, 2014
Where is it leaking from?
Maytag MAV6200... | Answered on Dec 04, 2012
Could you please describe the problem you are having a little better?
could be two things
1) thrust bearing
2) transmission
Maytag MAV6200... | Answered on Jul 30, 2012
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Maytag MAV6200... | Answered on Dec 11, 2011
Hello, This Dr Maytag MIke.
This is your lucky day!! I am going to help you out for free, and give you several manuals for your unit. Service manual, Installation Manual, Owners manual and more. You will know more about your Maytag they Maytag does. All I request in return for my free help, is to rate me and some kind words would be nice, Thanks Dr. Maytag, Mike
https://www.maytag.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%206-2611110.pdf
https://www.maytag.com/digitalassets/MLPDF/Installation%20Instructions%20-%2062610010.pdf
https://www.maytag.com/digitalassets/MLPDF/Dimension%20Guide%20-%20DMATLWSH-DD.pdf
https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20MAV6200AWW.pdf
AND FINALLY HERE IS THE LINK TO MY PERSONAL PAGE OF ALL MY AREAS OF EXPERTIZE.
http://beta.fixya.com/users/mc1beanThanks again, and happy washing. Mike
Maytag MAV6200... | Answered on Oct 22, 2011
My name is mike, I am going to help you out. here is some links that have everything to do and more with your washer. Please rate my free solution and some kind words would be great....
https://www.maytag.com/digitalassets/MLP...
http://home.howstuffworks.com/how-to-rep...
Thanks again, Mike, "If I can't fix it, its not broken"
Hi
The drain pump assembly requires cleaning...you'll have to take it apart to clean the drain pump assembly. If after cleaning the issue returns then the drain pump should be replaced. Please check this video on how to clean/replace the drain pump assembly:
Hope this helps...please post back for further assistance.
Daniel
Maytag MAV6200... | Answered on Feb 02, 2011
Is it a constant squeak or does it go squeak-squeak - squeak as it agitates? It is a squeak that is intermittant then usually your brake is losing its hold. You will need a technician to do this job. It requires special tools that they should have. I repeat a technician should do this job. You can seriously hurt yourself attempting this repair. Also see if the inner tup is turning as it agitates, if it is then it i definately the brake. But one more time do not try this repair it is a dangerous repair that should be left to technicians. There is a spring that is under heavy compression that requires a tool to release it.
Maytag MAV6200... | Answered on Dec 28, 2010
You need a water valve because debris has gotten in to the valve causing it not to close completely.
Maytag MAV6200... | Answered on Dec 02, 2010
Hi
You could have a worn out drive pulley/cam not raising the brake far enough to release or a leaking tub seal has rusted and locked the spin bearing up.
Remove front, tilt the machine back against a wall, remove the drive belt and turn the main transmission pulley, (the one in the center of machine), one way will make it agitate the other should make the pulley raise up on the cam ramp and release the brake letting the transmission turn. When you turn the pulley in the direction for spin, if the transmission doesn't want to turn try grabbing hold of transmission and turn it by hand while turning pulley.
If the ramp on the pulley/cam has worn down you can do a tempory fix by installing a thicker or extra washer between part ref# 4 and 6 to compensate for the worn cam ramp. Also check all parts in ref#24 to make sure all thrust washer and bearings are intact.
Do you notice any signs of water leakage at the top of the transmission, if so this would indicate the center tub seal has been leaking water and frozen up the main spin bearing.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Maytag MAV6200... | Answered on Jul 25, 2010
Use a volt/ohm meter to check the lid switch for continuity.
Maytag MAV6200... | Answered on Jul 24, 2010
i found out how to do it at bobvila.com
Maytag MAV6200... | Answered on Jul 11, 2010
Some where on the machine I do not know were because different model put them in all places. you will find a reset button this should be red press it and release it an machine should work again. Best of luck
Maytag MAV6200... | Answered on Jun 02, 2010
Washing Machines Logo
44 questions posted
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
need manual maytag atlantis washer model
  • Washing Machines
