20 Most Recent Sony 21" Trinitron P202 Flat Screen Monitor Questions & Answers
ask sony yet? and they charge money for there service manual
and substitutions would be the most complex question possible.
only sony knows this.
Sony 21"... | Answered on Sep 15, 2019
Do you use the remote control or buttons on the tv itself? Many TVs have a child lock feature that will prevent operating the TV without the remote control. If you use the remote control you should be able to change chanels, and to disable the child lock from the menu.
Sony 21"... | Answered on Jun 09, 2008
what is wrong? its damaged internally on one of the pcb boards most likely the power board, you will need to take it in to a service center to know what is exactly wrong
Sony 21"... | Answered on May 11, 2008
problem lies in the power supply check opto coupler or check horizontal output transistor and lot
Sony 21"... | Answered on Nov 22, 2007
Do you have sound in other applications?
You could try using VLC Media Player, instructions here:
https://www.thewindowsclub.com/play-blu-ray-on-windows-10
Sony Computers &... | Answered on Feb 12, 2020
Hello there... Sony seems a choosy brand so it looks like your disc is not recognized by it. Check also your disc for scratches or you just need to clean your disc first before you can use it. Try it. If this doesn't help, try inserting your disc to other CD-ROM. See if your disc is okay. Hope this helps...
Ai-ai :)
Sony Computers &... | Answered on Jan 20, 2020
The push-button activates a small motor that turns a small rubber belt/ band that opens the cassette door. Since it's not been used for 10 yrs, I would say these belts would have deteriorated and broken. you will need to replace them. the best bet is to open it up and check. if its the case, you should be able to source the belts on ebay.
Sony Computers &... | Answered on Dec 03, 2019
this is easy, that OUT OF range means
the PC sending video is sending and illegall higher resolution
than the projector supports (or even less, on this old junk)
the manual on that old projector is clear on that. max.
SONY VPL-EX4 2007, 13 years old now.
and back then projectors STINK !
your manual shows this, and stinks.
what stinks worse is no matrix of legal H./V resolutions shown in the manual. (shows only 1)
so set the PC to 1400 x 1050 and do not use others . ok.
and 60Hz, are you in USA? not stated country.
Sony Computers &... | Answered on Nov 28, 2019
no OS stated, W10?
the drivers for your camera/mic are wrong, reload them from SONY..com
Looks like you are having a bad LCD screen, This could be due to drop damage. Cracks can be so tiny and may not be visible immediately. I would take it to a technician and get a screen replacement.
Sony Computers &... | Answered on Nov 27, 2019
You probably need more ram memory. Also try playing a video in your dvd player. If it plays slow and choppy you definitely need more ram memory.
If you are trying to play a video from a website (streaming) then three things can affect how smooth it plays.
1) Memory - your ram memory might be low
2) The website might be experience heavy traffic from many users.
3) The Line Speed of your internet connection from your service provider might be slow. For example: AT&T sells about 3 or 4 different packages and each one increases the line speed for uploading or downloading. If you buy the low end package the line speed is very slow on uploading and downloading or streaming. It's ok for just surfing, but nothing else.
Sony Computers &... | Answered on Nov 08, 2019
1st leave the battery out,
then power only with AC power pack
push power for 10seconds and releases.
the batteries are bad, as more are, in the wild. most.
Sony Computers &... | Answered on Sep 12, 2019
all things can be repair,
only price to do so matters.
one mans garbage is others treasure.
can't speak for you ever.
but in my hands yes, garbage.
spend hard cash on newer more supported products.
2010 or newer is good rule.
Sony Computers &... | Answered on Aug 31, 2019
Might be motor-boating. Used to be a fairly common fault with older less sophisticated circuitry. The cause could be anything from a fault in an interim power supply to stray feedback causing an oscillation with a low speed harmonic. Considering your description it could be the latter - impedance mismatch maybe, between the external mic and the amp input...
Sony Computers &... | Answered on Aug 20, 2019
Sounds like you accidentally pressed the power button while you were dusting and turned it off. You just need to turn the HT-S200F back on.
It's the 1st button on the left of the control panel, which is located on top of the soundbar, in it's center. .
https://www.sony.com/electronics/support/res/manuals/4727/47274141M.pdf
Sony Computers &... | Answered on Aug 19, 2019
Have a look at VLC media player at http://www.videolan.org/vlc/ It's free and plays pretty much any video format, including DVDs
Sony Computers &... | Answered on Aug 16, 2019
Computers & Internet Logo
9 questions posted
Top Sony Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Computers & Internet
Most Popular Question
substitute str f6654 str f6707
  • Computers & Internet
