20 Most Recent
Jensen JP1500 Main / Stereo Speaker Questions & Answers
Receiver
you are over driving both your amp and the speakers.
do y9ou have speakers in parallel-- making the combined speakers less than 4 homs? also the cd is probably rated with ( i for got he initials it something like CDX whish has a 30 hertz base boom to it this is a good caution to observe becaus you may be overdriving both the speakers doing damage ( this becomes a DC component and is generating a lot of heat energy causing your amp to clip ( overheat) and the speaker to stop in mid stroke causing mechanical damage).
Get a bigger amp. Starts.
Get a balanced System
Go to a rock concert instead.
work at a jet engine factory.
Good luck
Call me im a doctor you will soon need new ear drums.
How to set time on jensen jcr-425
To set the time on a Jensen JCR-425 clock radio:
- Press and hold the "Time Set" button until the display flashes.
- Press the "Hour" and "Minute" buttons to adjust the time.
- Press "Time Set" again to confirm.
Jensen Compact Disc Music system JMC-500W. Open/Close button not opening the lid
Please hold down the open/close button instead of just pressing it. Then you can press the lid while this is happening. I think you might already suspect this, but it sounds like the hook that connects to a portion of the lid isn't unhooken during the button press. Friction might be a cause or the hook-movement might not be functioning as smoothly due to other factors.
If the issue continues, we might have to consult Jensen on a potential repair/replacement of the item as well.
