20 Most Recent
HP Pavilion M70 17" CRT Monitor Questions & Answers
I need to make the
what browser you use you should be able to hold down your ctrl key as you scroll the mouse button up or down to make the page smaller or bigger. just make sure your mouse is click first in the browser page someplace in an open area so its on that page..
Color problems with moniter
check that the data cable is connected firmly, if it is check that there are no curved or brocken pins.
open the computer and firmly press on the graphic card into his socket, close coputer case.
Screen is whitish and its
The Cathode Ray Tube (CRT) can develope a short circuit in the neck area of the tube that will cause this. I suggest that you remove the plastic cover of the monitor, and tap on the neck of the cathode ray tube with the plastic handle side of a screw driver. Be careful while the cover is off of the monitor not to touch any wires or the high voltage wire that connects to the side of the tube. There is very high voltage used to operate the CRT and it will zap you!!
My HP Pavillion M70 monitor is saying "video cable
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located
at the lower left of the keyboard, normally between the CTRL and the ALT
key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external
display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5,
Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations
with the age of the laptop and not all manufacturers have standardized on
a key combo across the whole range, but you can usually figure it out from
the little graphics on the function keys that line the top of the keyboard.
Overstretched screen
the circuitry to regulate the screen size and the height and width has failed and your crt need service but it would be more expensive to repair than to purchase a new LCD monitor.
the control pots or resistors usually go out on a crt over a period of time and have to be replaced This is very expensive. Also with the pots the capacitors in line with the resistors have to be replaced. Then there are the regulator components such as a LM317 which regulates the voltage to the circuit to keep it at constant voltage for the pots to adjust.
The picture and all graphics are pixulated
istall graphics driver,if already installed rightclick and unistalled driver and install new driver, you can find correct driver using mydriver , use this link
http://www.softpedia.com/get/System/Back-Up-and-Recovery/My-Drivers.shtml
Green screen
From your lines... 'Tapping the side of the monitor' Reminds me cracked solder joints. You need to check for this.
First open the Chassis and narrow down the area of the circuit board where exactly applying force makes the monitor fine and in that area of board / around that area look for cracked solders. Definitely this will help you.
Monitor is blank but green light is on
if you disconnect the data cable while the monitor is on, you should get a red and cyan message telling you to check the cable, that assures you that the problem does not coming from the monitor, instead check th video card.
M70 crt
just check the power cable from the monitor is connected properly or not try reconnecting it...
may be there is some loose contact in power cable............
check the cable which connects the cpu from the monitor is connected properly check whether is there any loose contact try reconnecting it...........
if problem persists then there is a problem with operating system try reinstalling it....
White Sharp Horizontal Streak on Center Screen
Hello RepairKid,
Although it's difficult to pinpoint which solder point(s) are the cause of a problem of this nature, the use of a magnifying glass will help you determine which solder point(s) look "irregular" compared to the other ones. Look for cracks or pits across the solder point and re-solder once found. Sometimes a hairline of solder is shorting out two points and again is might not be possible possible to see without magnification. If you don't notice any irregular solder points, a component could be causing the problem (like a very dirty/oxidized potentiometer or a cracked discrete / SMD). Let me know if this helps.
cancerags
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
