20 Most Recent Maytag Performa PAV3200 Questions & Answers
3answers
Rips and tears in clothes
The washer could be developing a transmission problem. As the washer agitates, the plastic tub is suppose to remain still. If the transmission is starting to slip, it will also try to spin during the agitate cycle, thus making the clothes become tangled under the agitator.
3/31/2015 2:57:54 PM • Maytag Performa... • Answered on Mar 31, 2015
Maytag sav205daww will not go into high spin. agitate and slow spin are fine
Ck the belt / idler pulley.
9/1/2014 4:26:25 PM • Maytag Performa... • Answered on Sep 01, 2014
0answers
Top part of agitator comes off bottom part
The "dogs" and retaining plate are broken or missing. If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
12/11/2013 7:39:13 PM • Maytag Performa... • Answered on Dec 11, 2013
Maytag performa pav3200 washing mach. very load shrill noise during spin
if you just bought it it probably is the shiping pin. it is a large boldt in the back of the front load machines, smaller pin in the side or rear on toploaders. it keeps the drum from spinning in transit. people forget to pull them all the time. especially if you installed it yourself. If that isnt the problem, try leveling it. Newer machines spin much faster than older ones and one tiny bit off level will make it rattle and shake.
1/6/2013 6:02:11 AM • Maytag Performa... • Answered on Jan 06, 2013
If I put soap in fabric softner spot can I just add water and let it drain out?
You could remove it and clean it out. Or you can add water a few times and put it in a spin. It will only release in the spin cycle.
12/31/2012 5:50:18 PM • Maytag Performa... • Answered on Dec 31, 2012
Maytag dryer waont start when you push start button
Try opening and closing the door a few times it might be the door interlock switch, Are your plugs fused like in the UK. If so check fuse, or there will be a safety fuse inside the dryer which has blown in which case it will have to be examined by a qualified repairer.
11/14/2011 6:42:38 PM • Maytag Performa... • Answered on Nov 14, 2011
How to take out jatater
Hello, williamI am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.http://home.howstuffworks.com/how-to-repair-a-washing-machine.htmPlease if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help. http://beta.fixya.com/users/mc1beanThanks Mike
11/6/2011 6:27:13 AM • Maytag Performa... • Answered on Nov 06, 2011
My washer(PAV3200-2) was working fine,
I would suspect that the small noise is from the drain motor which might be jammed by something!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
7/7/2011 1:40:02 PM • Maytag Performa... • Answered on Jul 07, 2011
Hi maytag performa pav3200 failing
you may have a stuck tub bearing.tilt machine at a 45 degree angle take off belt and turn transmission pulley both ways. One way will be easy for the wash cycle and other more resistant but should be able to turn i nner tub or else their is your problem. To change this bearing need special tools.
7/3/2011 1:01:19 AM • Maytag Performa... • Answered on Jul 03, 2011
Washing Machines Logo
133 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Oloyede Monsuru
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
noisy when in agitation or spin mode
  • Washing Machines
