20 Most Recent Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher Questions & Answers
Welcome to FixYa.
Based on your description I'd say the issue actually is with the control...unfortunately. This is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated. Copy & paste this link (or click on it if it will respond) to your toolbar (explorer bar ?) and you'll see my complete solution for this issue.
http://www.fixya.com/support/t8763034-good_afternoon
I also wanted to add, depending on your model and serial number Bosch issued a recall on some of their units. Here's a link you can use to check up on your specific unit.
http://microsites.boschappliances.com/safetyrecall/dishwasher/
Good luck.
Regards,
Macmarkus :)
Bosch 24 in.... | Answered on May 31, 2019
Fix what you see then try to see what it does before go any further.
Good luck
mai
Bosch 24 in.... | Answered on Jan 16, 2018
Could be a weak or defective pump.
Bosch 24 in.... | Answered on Dec 13, 2017
Press Cancel twice, and start cycle over.
Bosch 24 in.... | Answered on Nov 26, 2014
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Bosch 24 in.... | Answered on Mar 10, 2014
Hello, dcmckenzi
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Bosch 24 in.... | Answered on Oct 27, 2011
Hi 2ipnelson,
Very difficult to know for sure which part is not working.
It is best to run the dishwasher in testing / service mode to ascertain which component is not working.
I found a .pdf document that explains the whole process, it should also work for your SHE model.
The link: LINK - CLICK HERE
Follow the steps, and the culprit part should be diagnosed.
Hope this helps :-)
* If this solution helped you, please accept it
Bosch 24 in.... | Answered on Jul 27, 2011
Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher Logo
60 questions posted
Top Bosch Dishwashers Experts
peter gittos
peter gittos
Marvin
Marvin
Ekse
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
small leak bottom right hand
  • Dishwashers
