20 Most Recent Bosch HBL 5032 Electric Single Oven Questions & Answers
There are several things that could be faulty. Have you checked that the old element had actually failed after you pulled it out. Try checking the thermostat, the switch that turns the oven on, and that you installed all the wires back on correctly when you swapped the element. Also check there is power on the oven.
Bosch HBL 5032... | Answered on Jan 07, 2018
If the fan is working o/k, then it is sure to be the oven element that is faulty, a common fault with fan ovens, replace element, and it should be o/k.
Please rate my soluti9on.
Thanks.
Bosch HBL 5032... | Answered on Nov 02, 2011
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Bosch HBL 5032... | Answered on May 19, 2011
Hello, Most of the temp. & select knobs do extend out, but not automatically. If you push the knob inward and release, they should individually "pop" extend out to allow them easier to function. As I indicated this is how most modern bosch work, with the acception of some models. Please provide your actual model number if you require further help. Hope that answer's you question, let me know if I can assist you further. Good luck, please rate this solution accordingly and thanks for coming to "fixya". Macmarkus :)
Bosch HBL 5032... | Answered on Apr 01, 2010
If you have a BOSCH electric Cooker or Fan Oven which isnot heating it could be one of the following problems.
1, If the fan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter.
To gain access to the BOSCH element you will have to remove the back platefrom inside the oven. Once removed you will see the fan and element,if you look closely at the element you will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your BOSCH fan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into theoven then you need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your BOSCH oven thermostat
4, A quite commonand easily overlooked answer is if your BOSCH oven is not working at all ie: no heatand no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Bosch HBL 5032... | Answered on Jan 24, 2010
Tip
Common heating faults with Bosch HBL 5032 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 5032 Electric Single Oven
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Bosch HBL 5032... | Answered on Jul 14, 2009
Hi.
You will need to check the oven element, it probably needs replacing.
Thanks.
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Bosch HBL 5032... | Answered on Feb 13, 2009
REPAIR IS NOT POSSIBLE BUT REPLACEMENT IS BUY A NEW SWITCH
Bosch Ovens | Answered on Jul 03, 2020
WELL THEN TURN THE ONE THAT LOOKS LIKE A CLOCK AND SEE WHAT YOU ACCOMPLISH
Bosch Ovens | Answered on Jul 01, 2020
Certainly the hinge(s) are replaceable though while some are simple others are a major dismantling job - needing to take the assembly back to the point the hinges were originally fitted.
Parts list and diagram can be found on the link below.
https://www.bosch-home.com/us/supportdetail/product/HBL5032AUC/01#/Tabs=section-spareparts/
Bosch Ovens | Answered on May 18, 2020
Sounds Like child lock activated check owner manual or send us a model # glad to help more
Bosch Ovens | Answered on Feb 23, 2020
Bosch HBL 5032 Electric Single Oven Logo
25 questions posted
Top Bosch Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
View Most Popular
Bosch Ovens
  • Bosch Ovens
Most Popular Question
whirlpool fan assisted oven fan working
  • Ovens
