20 Most Recent Panasonic CT-27SX11 27" TV Questions & Answers
manual
Panasonic 32 inch TV has horizontal lines across screen
REPLACE VERICAL OUTPUT IC ' LA7838
2/5/2009 12:10:36 PM • Panasonic... • Answered on Feb 05, 2009
CT-36HX42F
I had the same problem. Sometimes the processor gets overheated, particularly when dealing with high definition signals. Unplug the television from the power strip or wall outlet and it should reset everything. When you plug it back in it should work. Not a long-term solution, I know, but it will get your TV working again.
1/10/2009 3:05:24 PM • Panasonic... • Answered on Jan 10, 2009
I get horizontal Line on the screen no picture, Panasonic Std 27''
bad electrolytic vertical circuit. need tech,
12/2/2008 7:15:38 PM • Panasonic... • Answered on Dec 02, 2008
Tv will not recieve signal from remote
There is a sensor in the tv you could get replaced which gos bad sometimes. It is most of the time not expensive.
thanks Doctor video
7/11/2008 4:02:10 AM • Panasonic... • Answered on Jul 11, 2008
Fixing Tilt
YOU PROBABLY TOUCH THE SCREEN VOLTAGE ADJUSTMENT LOCATED ON THE FLYBACK TRANSFORMER. BECAREFUL ADJUSTING IT LPUS IT IS HIGH VOLTAGE USE A PLASTIC ADJUSTMENT DRIVE.
THANKS DOCTOR VIDEO
4/27/2008 2:21:19 PM • Panasonic... • Answered on Apr 27, 2008
Top half of picture blanked off
the problem is in your deflection coil, the other half had been shorted probably.
4/25/2008 1:51:11 PM • Panasonic... • Answered on Apr 25, 2008
Trying to Fix Tilt
i think your TV has develop a many loose soldered parts on it.physically it was on the Brightness circuit portion.one way to restore it is to resolder all loose part on cicuit board...
4/25/2008 1:45:55 PM • Panasonic... • Answered on Apr 25, 2008
Dysfuntional TV/Video selection
thats a tricky one.. If there is no restriction or parental restriction setting in the menu then i would say that something went out on your back A/V panel... and probably not easly replaceable. probably would be better off looking at a new TV and hand that one down to the kids or put it in a shop or another room in the house.
Hope its a menu setting.. good luck.. let me know what you find.
1/22/2008 8:28:10 PM • Panasonic... • Answered on Jan 22, 2008
I have a Panasonic TV the remote was lost programed a unversal remote hit the aux button tv did a error search told not to turn tv off everything ok except EPOP 101
If the EPOP 101 error message appears when you try to program the universal remote, it is likely that the remote is not compatible with your Panasonic TV. You may need to purchase a remote specifically designed for your Panasonic TV model.
3/17/2023 11:13:13 AM • Panasonic... • Answered on Mar 17, 2023
Why my Panasonic VCR not ejecting?
Motors or drive belts not working. Google panasonic model tape not ejecting https://www.google.com/search?q=%E2%80%8Bpanasonic+model+tape+not+ejecting Press and hold the [EJECT] button on the unit while plugging in the power cord. You can also try on the remote control to press [Drive Select] to select VHS drive and then press and hold for more then 3 seconds the [STOP] button.
The VHS tape is stuck how to eject the VHS tape.
3/15/2023 5:20:58 AM • Panasonic... • Answered on Mar 15, 2023
Panasonic dmr-bs850eb Freesat has lost bbc1 Channel 101 after the recent HD upgrade - can it be fixed?
Sorry no answer but can confirm I have the same issue with a DMR BS750 (same machine smaller hard drive ) connected to a Panasonic TX-L37G10B. DMR no BBC1 but BBC 1 ok on the TV have you had any luck with an answer? [email protected]
3/12/2023 9:31:01 PM • Panasonic... • Answered on Mar 12, 2023
We have a Freesat Panasonic Blu Ray recorder DMR-BS750 Which will not record BBC1 since it went HD. We can record BBC2 HD and most other channels.
It's possible that your Freesat Panasonic Blu Ray recorder DMR-BS750 may not be compatible with the specific HD format used by BBC1. Here are some troubleshooting steps you can try:
Check that your Freesat Panasonic Blu Ray recorder is updated with the latest firmware. An outdated firmware can cause issues with recording.
Check if the recording schedule is set up correctly for BBC1 HD. Make sure that the start and end times are accurate and that the program is not set to record in series.
Try resetting your Freesat Panasonic Blu Ray recorder to its factory settings. This will clear any possible software errors and may help to resolve the issue.
If none of these steps work, you may need to contact Panasonic customer support for further assistance. They may be able to provide additional troubleshooting steps or recommend a firmware update or other solution.
It's also worth noting that some broadcasters may use proprietary or non-standard HD formats that are not compatible with all devices. If this is the case with BBC1 HD, it's possible that your Freesat Panasonic Blu Ray recorder may not be able to record this channel.
3/6/2023 11:12:13 PM • Panasonic... • Answered on Mar 06, 2023
How to get into service mode, Panasonic DMR-BCT750
To access the service mode on a Panasonic DMR-BCT750 Blu-ray disc recorder, follow these steps:
  1. Turn on the recorder and wait for the "Welcome" message to appear on the display.
  2. Press and hold the "OK" button on the remote control for approximately 5 seconds.
  3. The service menu will appear on the TV screen. Use the arrow keys on the remote control to navigate the menu.
Note: It's important to be careful when accessing the service mode as it allows access to advanced settings that can affect the operation of the device. Make sure to only make changes if you have a clear understanding of what you're doing, or seek assistance from a qualified technician if you're unsure.
3/3/2023 9:27:28 PM • Panasonic... • Answered on Mar 03, 2023
Rosen piranha multimedia navigation head unit disk try isn't reading a CD for the DVD player
If your Rosen Piranha multimedia navigation head unit is not reading CDs and the DVD player is not working properly, there are a few things you can try:
  1. Check the disc: Make sure the disc you are trying to play is clean and free from scratches or other damage. If the disc is dirty, clean it gently with a soft cloth.
  2. Check the format: Make sure that the disc you are trying to play is compatible with the DVD player. The DVD player may not be able to read certain formats, such as Blu-ray discs.
  3. Check the connection: Make sure that the cables connecting the DVD player to the head unit are properly connected and not damaged. Try disconnecting and reconnecting the cables to see if that resolves the issue.
  4. Check for firmware updates: Check the manufacturer's website to see if there are any firmware updates available for your Rosen Piranha head unit. Updating the firmware may resolve any software-related issues that are causing the DVD player to malfunction.
  5. Reset the head unit: Try resetting the head unit to its factory settings. This may resolve any software-related issues that are causing the DVD player to malfunction.
If none of these steps resolve the issue, it's possible that there is a problem with the DVD player itself. In that case, you may need to have it serviced or replaced by a qualified technician.
3/3/2023 3:58:10 AM • Panasonic... • Answered on Mar 03, 2023
2answers
What board would you replace on a panasonic LCD TV model TC-55LE54 if you are getting a blackscreen
Hi Chris! It could be one of 4 things causing no backlights, LED driver, main, and power board, also it's possible the actual backlights have failed however Panasonic sets haven't seen this issue like most other brands have. Do you have a multi meter and can get some voltage readings? With out them it's a guessing game as to what board or boards are bad
3/3/2023 1:05:06 AM • Panasonic... • Answered on Mar 03, 2023
Panasonic DVD RV62 displays message 'Bye' and does not respond
The message 'Bye' typically appears on Panasonic DVD players when the power is turned off. If your DVD player is displaying this message and is not responding to any commands, it could indicate a power issue or a problem with the player's firmware. To troubleshoot, try unplugging the player from the power source and plugging it back in after a few minutes to see if it resets. If this does not work, try pressing and holding the power button on the player for several seconds to see if it turns on. If these steps do not work, it may be necessary to take the player to a technician or contact Panasonic customer support for further assistance.
2/28/2023 5:55:03 AM • Panasonic... • Answered on Feb 28, 2023
Need codes for a panasonic
yes
2/26/2023 8:16:51 PM • Panasonic... • Answered on Feb 26, 2023
I need the remote code for this Panasonic Light Tower universal remote to operate my Hiteker TV ," model # HK133K2-SC
How to Program a Panasonic Light Tower Remote Control
https://www.techwalla.com > Tech Support > How To The Panasonic Light Tower is a VCR remote that allows you to control the TV and other components of your home entertainment system.
2/25/2023 8:28:49 PM • Panasonic... • Answered on Feb 25, 2023
Hi, I have a Panasonic dmr-bs850 which has lost all freesat channels & when I try to auto retune it keeps saying, Astrabird 2 cannot be found, my dad had the identical machine which developed the exact same problem, I have done all the obvious things to try & resolve the issue but to no avail. Any ideas, thanks Stuart
I have the same machine. There was a court case regarding this pvr. I think it came down to the fact that panasonic didn't allow for the full spectrum of DV3 and won't do a firmware update. The new HD channels cannot be received. Most of these models are more than 6years old so we have no legal rights. I could get all local BBC channels before they went HD now just a few. I live miles from my home and it was nice to receive my homes local news. BBC has taken it upon itself not to care about pvrs so it seems and are moving more towards social media.
2/22/2023 6:59:35 PM • Panasonic... • Answered on Feb 22, 2023
Panasonic CT-27SX11 27" TV Logo
Popular Tags
11 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
dysfuntional tv video selection
  • Televison & Video
