20 Most Recent Maytag MAV7600 Top Load Washer Questions & Answers
motor winding's are faulty .replace motor and you are back in business.
Maytag MAV7600... • Answered on Mar 14, 2014
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Maytag MAV7600... • Answered on Dec 21, 2013
if the washer keeps taking water and even when the washer is on the off position. The problem could be a bad water valve.
Maytag MAV7600... • Answered on Nov 19, 2013
Water Valve Maytag Original Top Load WasherIf the problem with your Maytag washer is that is not filling properly, not taking cold water, not taking hot water, or not taking any water at all. Or if the washer keeps taking water and overflows even when the washer is on the off position. The problem could be a bad water valve. To check it out, do the following. 1. Disconnect the washer from the wall outlet 2. Open the controls panel 3. Remove the cabinet 4. Set your multimeter to read more than 2000 ohms 5. Take a reading between the two terminals on the two solenoids on the water valve 6. The reading should be between 700 and 1800 ohms on each solenoid If the reading is infinity on any solenoid, the water valve is bad and most be replaced
Maytag MAV7600... • Answered on Nov 18, 2013
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first. Enter your model number to see parts for your washing machine. Help me find my model number
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer. Enter your model number to see parts for your washing machine. Help me find my model number
Line Fuse
If the washer won't start the line fuse might have blown. Enter your model number to see parts for your washing machine. Help me find my model number
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information. Enter your model number to see parts for your washing machine. Help me find my model number
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced. Enter your model number to see parts for your washing machine. Help me find my model number
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first. Enter your model number to see parts for your washing machine. Help me find my model number
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Enter your model number to see parts for your washing machine. Help me find my model number
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Enter your model number to see parts for your washing machine. Help me find my model number
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity. God bless you3958e768-3a49-432b-8096-35c2e90be05f.gifbf55c0bf-2b61-4cdd-8831-a6dc82140f68.jpg
Maytag MAV7600... • Answered on May 23, 2013
Check inside to see if one of the drum springs has come off or broke.
Maytag MAV7600... • Answered on Nov 04, 2012
Maytag MAV7600 Top Load Washer Logo
98 questions posted
Top Maytag Washing Machines Experts
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
motor turn
  • Washing Machines
