20 Most Recent Panasonic TC-32LX60 32 in. LCD Television Questions & Answers
Good day, I am reading that this is a circuit failure. I would refer you to a technician to repair/replace the board. Good luck...
Panasonic... • Answered on Dec 04, 2017
Ours is doing the exact same thing! I came here hoping to find an answer. Did you figure your tv out?
Panasonic... • Answered on Mar 13, 2015
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Panasonic... • Answered on Aug 11, 2014
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Panasonic... • Answered on Jun 23, 2014
can you get sound from the back RCA connectors (red and Yellow ) to a sound bar. if yes I have see a-lot of TV off the line that the connector at the bottom of the MAIN board is disconnected....
Panasonic... • Answered on May 25, 2014
6 times flahes denotes main power regulator board fault. Check for it. To get some information, http://electronicshelponline.blogspot.com/Pull up older posts. Blinking code details to Panasonic Plasma TVs are given.
Panasonic... • Answered on Dec 03, 2013
DON'T wiggle it anymore because the connection solder points are loose and you will eventually crack the connector or the PCB it's soldered to. If it is not to much hassle you can remove the TV/Case cover and hit the points with a soldering iron.
Panasonic... • Answered on Nov 11, 2013
Thank God for the internet. I had the same problem and I googled it and found this site with this solution. It worked fine. Thank you. Like you said, unplug, hold the power button for 60 seconds and replug and turn on. Worked like a charm. Thanks a bunch.
Panasonic... • Answered on Jun 19, 2013
Most likely is the LCD panel hit by something and damaged. It possible costs you more to fix it than to buy a new one.
Panasonic... • Answered on Jul 26, 2012
Panasonic TC-32LX60 32 in. LCD Television Logo
74 questions posted
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
no power but red light flashing
  • Televison & Video
