20 Most Recent Panasonic DVD-LX97 Portable DVD Player Questions & Answers
We have a Panasonic DVD-LX97 which is displaying
THE ERROR MESSAGE IS.
"YOU ARE TRYING TO CHARGE THE UNIT IN TEMPERATURES OUTSIDE OF THE UNITS NORMAL WORKING RANGE.
either too hot or cold.
try experimenting by cooling the player if its warm where you are or warming it if its cold.
if it still doesnt work when the player is in normal room temperature ( ie 10 degrees celsius to 24 degrees celcius) then the internal thermal trip is faulty and needs resetting ( a board change i would think)
not worth the time and expense for a discontinued player .
ps heres a link to the manual online
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/Portable-DVD-Players/model.DVD-LX9
2/7/2010 9:52:24 PM • Panasonic... • Answered on Feb 07, 2010
3answers
H03 Error
This problem is the laser optics in the wrong position.
Try to move it carefully by hand to the left near the spindle.
It may be stuck on the right side.
Please let us know what you see!
1/5/2008 2:41:06 AM • Panasonic... • Answered on Jan 05, 2008
Panasonic AV Control Receiver SA-HT05 - which code for universal remote? I have DENON RC-1005, Savio RC-02, LCD Touchscreen Universal Remote
To program a universal remote control for your Panasonic AV Control Receiver SA-HT05, you will need to know the remote control code. There are a few ways to find this code. First, you can check the manual that came with your universal remote control. Look for a list of codes for different devices, including the Panasonic AV Control Receiver SA-HT05. Find the code that corresponds to your receiver model. If you can't find the code in the manual, you can search online for a list of remote control codes for the Panasonic AV Control Receiver SA-HT05. There are many websites that offer this information for different models of devices. If neither of these options works, you can try entering different codes from the list provided by your universal remote control manufacturer. Follow the instructions provided in the manual for how to enter the code, and try different codes until you find one that works. It's important to note that not all universal remote controls are compatible with all devices. If you're unable to find a code that works with your Panasonic AV Control Receiver SA-HT05, you may need to purchase a remote control that is specifically designed for that receiver model.
3/26/2023 9:44:29 AM • Panasonic... • Answered 3 days ago
I have a Panasonic TV the remote was lost programed a unversal remote hit the aux button tv did a error search told not to turn tv off everything ok except EPOP 101
If the EPOP 101 error message appears when you try to program the universal remote, it is likely that the remote is not compatible with your Panasonic TV. You may need to purchase a remote specifically designed for your Panasonic TV model.
3/17/2023 11:13:13 AM • Panasonic... • Answered on Mar 17, 2023
Why my Panasonic VCR not ejecting?
Motors or drive belts not working. Google panasonic model tape not ejecting https://www.google.com/search?q=%E2%80%8Bpanasonic+model+tape+not+ejecting Press and hold the [EJECT] button on the unit while plugging in the power cord. You can also try on the remote control to press [Drive Select] to select VHS drive and then press and hold for more then 3 seconds the [STOP] button.
The VHS tape is stuck how to eject the VHS tape.
3/15/2023 5:20:58 AM • Panasonic... • Answered on Mar 15, 2023
Panasonic dmr-bs850eb Freesat has lost bbc1 Channel 101 after the recent HD upgrade - can it be fixed?
Sorry no answer but can confirm I have the same issue with a DMR BS750 (same machine smaller hard drive ) connected to a Panasonic TX-L37G10B. DMR no BBC1 but BBC 1 ok on the TV have you had any luck with an answer? [email protected]
3/12/2023 9:31:01 PM • Panasonic... • Answered on Mar 12, 2023
We have a Freesat Panasonic Blu Ray recorder DMR-BS750 Which will not record BBC1 since it went HD. We can record BBC2 HD and most other channels.
It's possible that your Freesat Panasonic Blu Ray recorder DMR-BS750 may not be compatible with the specific HD format used by BBC1. Here are some troubleshooting steps you can try:
Check that your Freesat Panasonic Blu Ray recorder is updated with the latest firmware. An outdated firmware can cause issues with recording.
Check if the recording schedule is set up correctly for BBC1 HD. Make sure that the start and end times are accurate and that the program is not set to record in series.
Try resetting your Freesat Panasonic Blu Ray recorder to its factory settings. This will clear any possible software errors and may help to resolve the issue.
If none of these steps work, you may need to contact Panasonic customer support for further assistance. They may be able to provide additional troubleshooting steps or recommend a firmware update or other solution.
It's also worth noting that some broadcasters may use proprietary or non-standard HD formats that are not compatible with all devices. If this is the case with BBC1 HD, it's possible that your Freesat Panasonic Blu Ray recorder may not be able to record this channel.
3/6/2023 11:12:13 PM • Panasonic... • Answered on Mar 06, 2023
How to get into service mode, Panasonic DMR-BCT750
To access the service mode on a Panasonic DMR-BCT750 Blu-ray disc recorder, follow these steps:
  1. Turn on the recorder and wait for the "Welcome" message to appear on the display.
  2. Press and hold the "OK" button on the remote control for approximately 5 seconds.
  3. The service menu will appear on the TV screen. Use the arrow keys on the remote control to navigate the menu.
Note: It's important to be careful when accessing the service mode as it allows access to advanced settings that can affect the operation of the device. Make sure to only make changes if you have a clear understanding of what you're doing, or seek assistance from a qualified technician if you're unsure.
3/3/2023 9:27:28 PM • Panasonic... • Answered on Mar 03, 2023
Rosen piranha multimedia navigation head unit disk try isn't reading a CD for the DVD player
If your Rosen Piranha multimedia navigation head unit is not reading CDs and the DVD player is not working properly, there are a few things you can try:
  1. Check the disc: Make sure the disc you are trying to play is clean and free from scratches or other damage. If the disc is dirty, clean it gently with a soft cloth.
  2. Check the format: Make sure that the disc you are trying to play is compatible with the DVD player. The DVD player may not be able to read certain formats, such as Blu-ray discs.
  3. Check the connection: Make sure that the cables connecting the DVD player to the head unit are properly connected and not damaged. Try disconnecting and reconnecting the cables to see if that resolves the issue.
  4. Check for firmware updates: Check the manufacturer's website to see if there are any firmware updates available for your Rosen Piranha head unit. Updating the firmware may resolve any software-related issues that are causing the DVD player to malfunction.
  5. Reset the head unit: Try resetting the head unit to its factory settings. This may resolve any software-related issues that are causing the DVD player to malfunction.
If none of these steps resolve the issue, it's possible that there is a problem with the DVD player itself. In that case, you may need to have it serviced or replaced by a qualified technician.
3/3/2023 3:58:10 AM • Panasonic... • Answered on Mar 03, 2023
2answers
What board would you replace on a panasonic LCD TV model TC-55LE54 if you are getting a blackscreen
Hi Chris! It could be one of 4 things causing no backlights, LED driver, main, and power board, also it's possible the actual backlights have failed however Panasonic sets haven't seen this issue like most other brands have. Do you have a multi meter and can get some voltage readings? With out them it's a guessing game as to what board or boards are bad
3/3/2023 1:05:06 AM • Panasonic... • Answered on Mar 03, 2023
Panasonic DVD RV62 displays message 'Bye' and does not respond
The message 'Bye' typically appears on Panasonic DVD players when the power is turned off. If your DVD player is displaying this message and is not responding to any commands, it could indicate a power issue or a problem with the player's firmware. To troubleshoot, try unplugging the player from the power source and plugging it back in after a few minutes to see if it resets. If this does not work, try pressing and holding the power button on the player for several seconds to see if it turns on. If these steps do not work, it may be necessary to take the player to a technician or contact Panasonic customer support for further assistance.
2/28/2023 5:55:03 AM • Panasonic... • Answered on Feb 28, 2023
Need codes for a panasonic
yes
2/26/2023 8:16:51 PM • Panasonic... • Answered on Feb 26, 2023
I need the remote code for this Panasonic Light Tower universal remote to operate my Hiteker TV ," model # HK133K2-SC
How to Program a Panasonic Light Tower Remote Control
https://www.techwalla.com > Tech Support > How To The Panasonic Light Tower is a VCR remote that allows you to control the TV and other components of your home entertainment system.
2/25/2023 8:28:49 PM • Panasonic... • Answered on Feb 25, 2023
Hi, I have a Panasonic dmr-bs850 which has lost all freesat channels & when I try to auto retune it keeps saying, Astrabird 2 cannot be found, my dad had the identical machine which developed the exact same problem, I have done all the obvious things to try & resolve the issue but to no avail. Any ideas, thanks Stuart
I have the same machine. There was a court case regarding this pvr. I think it came down to the fact that panasonic didn't allow for the full spectrum of DV3 and won't do a firmware update. The new HD channels cannot be received. Most of these models are more than 6years old so we have no legal rights. I could get all local BBC channels before they went HD now just a few. I live miles from my home and it was nice to receive my homes local news. BBC has taken it upon itself not to care about pvrs so it seems and are moving more towards social media.
2/22/2023 6:59:35 PM • Panasonic... • Answered on Feb 22, 2023
I have a Panasonic TC-P65ZT60 that flashes red light 3 times consistently
Page 50 and 53 of the Service Manual https://www.manualslib.com/manual/2311596/Panasonic-Tc-P55vt60.html?term=3+blinks&selected=3&page=50#manual 3 Blinks Yes A1 and disconnect the Blinking Is the power LED 3 times off or is it blinking 3 times continuously at a fast pace ? Replace the K board Applies to Models TC-P55VT60 TC-P60VT60 List of boards likely to cause this symptom. No specific order P, SS SC, A, K, Bluetooth module, Cs, Panel ..
2/15/2023 5:12:50 AM • Panasonic... • Answered on Feb 15, 2023
I have a 2010 Panasonic plasma TV. Model # tc-p54g25. It has a 10 blink code. Can you help me determine what part I need to repair my TV.
A 10 blink code on a Panasonic plasma TV typically indicates an issue with the power supply board. You will need to consult the service manual or contact a qualified technician to identify the exact part that needs to be replaced.
2/14/2023 10:39:05 PM • Panasonic... • Answered on Feb 14, 2023
I have a Panasonic DMR-EX87 HDD DVD Recorder. When I turn it on it just shows "Please Wait" then after about 10 minutes goes back to the clock. Any ideas how this can be fixed? Thanks
It sounds like there might be an issue with the hard drive or software of the recorder. You can try resetting the device to its factory settings and see if that resolves the issue. If not, you may need to have it looked at by a professional technician or contact Panasonic's customer support for further assistance.
2/14/2023 9:43:44 AM • Panasonic... • Answered on Feb 14, 2023
How do i program the lssq0263 remote to work on my
You have to press the tv then the number then the search/enter button codes are at https://c.searspartsdirect.com/pd-content/is/content/Sears/L0312229
2/5/2023 10:28:36 PM • Panasonic... • Answered on Feb 05, 2023
Cannot read a hard drive from a Panasonic wj hd316a DVR
Wrong format for computers to read.
1/30/2023 8:50:29 AM • Panasonic... • Answered on Jan 30, 2023
Panasonic DVD-LX97 Portable DVD Player Logo
5 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
panasonic dvd lx97 displaying
  • Televison & Video
