20 Most Recent Panasonic CQ-C1303U CD Player Questions & Answers
Check the RCA connections in the back of the unit
Panasonic... • Answered on Mar 28, 2011
when you take the face off try cleaning the connections behind it...
Panasonic... • Answered on Feb 07, 2011
i don't know what kind of car that you have but on that radio there should be two power wires one is red and the other is yellow,the red wire connects to the wire in the car that will only have power when the key is turned to the on position,the yellow wire connects to the wire in the car that always has power with the key off.........
Panasonic... • Answered on May 15, 2010
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Panasonic... • Answered on May 13, 2010
I have one. if you still need it email me: [email protected]
Panasonic... • Answered on Jul 30, 2009
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Panasonic... • Answered on Mar 25, 2009
this can be one of three things
1) the fuse on back of CD player could be blown
2) you need to push and hold the src/pwr button till unit powers on
as long as the yellow and red wire are attached to the positive battery wire you are good if the ground is to the battery ground and you try the first two steps i said and nothing happens........
3) ground the black wire from back of the CD player to any metal surface on the golf cart than try the first two steps again
it should power on if this is the case
hope i was able to help you
Panasonic... • Answered on Mar 06, 2009
Go to this weblink and click on the link at the bottom that says operating instructions. It will pop up with the entire manual for how to fully operate the system including settingthe clock.
http://www.generalmanual.com/Audio/Panasonic-CQ-C1303U-CD-Receiver.htm
Panasonic... • Answered on Mar 01, 2009
mine's doing the same thing and i don't know whats causing it either other than its a factory defect
Panasonic... • Answered on Apr 21, 2008
Cable de Memoria
Panasonic... • Answered on Apr 15, 2008
Hi Killie11, This is asimple thing to try. if it does not work email me at [email protected] Remove the face, and clean the contacts. You can get a contact cleaner spraycan at Radio Shack with a built in brush. This can clean the face plates connector and the head units connector. You should have power if the rest of the radio is doing what it is supposed to do. Hope this helps
Panasonic... • Answered on Oct 05, 2007
Panasonic CQ-C1303U CD Player Logo
Popular Tags
24 questions posted
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Michael Thomas
Michael Thomas
 TE5LA
TE5LA
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Car Audio & Video
Most Popular Question
car radio reset every time car turns off
  • Car Audio & Video
