20 Most Recent
Panasonic CQ-C8303U CD Player Questions & Answers
Panasonic CQ-C8303U. Hooked up an amplifier and it
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Panasonic...
Answered
on Sep 10, 2012
Face plate keeps opening and
If there is a reset switch, try pressing it. The reset switch is usually a pencil tip sized indentation on the face and will not be marked or will be behind the face on the sub panel.
Panasonic...
Answered
on May 18, 2011
Can this be hooked up
Yes it does as long as your phone supports bluetooth. Here's a link to the manual. You can download it for free. http://service.us.panasonic.com/OPERMANPDF/CQC8403U.PDF
Panasonic...
Answered
on Jan 12, 2011
I took my panasonic cq-c8303u
Check the in line cylinder fuse for the radio, cause they blow easy. Also, check the radio fuse under the dash or wherever your fuse box is located. Make sure you solder the connections for a good contact, cause just wrapping electrical tape around the wires will cause you problems down the road when you go over bumps.
Panasonic...
Answered
on Nov 11, 2010
Panasonic cq-c8303u wiring diagram
Panasonic...
Answered
on Oct 09, 2010
I have the panasonic cq-c8303u radio and i would
You need to get the Direct Cable for iPod® (CA-DC300U) from panasonic. This allows you to plug in and control your ipod from your headunit. There is also the expansion module (CY-EM100U), however I am not sure if this is necessary if you have the Direct Cable. The Direct Cable might plug directly into the back of the headunit without the need for the expansion module. Check with the company before purchasing one or both. If the direct cable requires the expansion module, then get both, however, I think the direct cable works independent from the expansion module. Again, contact the company about this. The expansion module also lets you plug your ipod as well as other devices into your headunit, however I don't think it allows you to control them via the unit. I think if you want to control the ipod from your headunit, you just need the Direct Cable for Ipod®.
Panasonic...
Answered
on Mar 23, 2009
SIRIUS RADIO
that unit has aux inputs in the back they are rca level inputs.. your "stratus" has an audio output that is a 3.5 mm jack or standard headphone jack, with the appropriate patch cord, you can connect the two devices giving you the best possible sound quality. you would use the aux source on the head unit to listen to sirius. this feature may need to be turned on in the menu.
Panasonic...
Answered
on Feb 21, 2008
Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I
Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Panasonic...
Answered
on Jun 20, 2007
