20 Most Recent
Maytag Neptune MAH7500A Front Load Washer Questions & Answers
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
I own a maytag neptune washing machine. It was
Hi Debi:First I suggest to try unplugging the unit for 60 seconds to reset the control board. If that doesn't work then open the dispenser and remove the softner and bleach container. There is a cord near the front you can pull to open the door lock. If you still have issues with your door lock after manually opening the door, you will need to order and replace the door latch assembly.Also I could bet you need to replace your door latch assembly. Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day.
The screen displays the following:
Judging by your comments I suspect there is likely to be a problem with either the door solenoid/lock or the door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Washer wont drain
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Why does my Maytag Neptune Washing machine smell
you have mold built up around the door boot. you need to buy a package of a product called AFRESH (3 tablets in it). follow the directions on the package. use one a month for maintenance on this machine. also, make sure you do one or two hot washes per month to keep the hoses cleaned from build up of soap and or fabric softener. leave the door open a little bit after each load.
We have a Maytag Neptune
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT:
[email protected] , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Shakes on spin cycle
yes bad struts can cause this problem also if you have it on carpet you would be better off cutting a piece of plywood for it to sit on as it will shake when sitting on carpet most of the time
Error code P6 -
please men help me my photo copie is not work bez of this how can i put a wet clocth on a eletric product
