20 Most Recent Maytag MAV8557 Top Load Washer Questions & Answers
Well, there are two main possibilities: Inlet valves and pressure sensor system. to test the inlet valves, turn off the machine, do they stop? Dirt can keep them open.
If power off stops the water, I suspect the pressure system. There is a component outside at the bottom of the drum that measures the water volume, using pressure. This collector component sometimes gets clogged with detergent. If it is open, test the transducer at the other end of the plastic hose. The system is designed to stop the power to the inlet valves when the pressure builds.
Maytag MAV8557... | Answered on Jun 11, 2011
This is most likely a problem with your drain line. Check to make sure it's not filling with water and that there is a gap around the line in the drain hole to prevent vacuum lock. Give the hose a good shake and see if that dislodges any stuck water.
You could also have something caught in the valve which is preventing it from opening and closing properly.
Maytag MAV8557... | Answered on Feb 28, 2011
Hi from retired Englishman in SW France
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning but I've not had any feedback of this nature.
Good luck,
John C
Maytag MAV8557... | Answered on Feb 18, 2011
Both kinds of maytag washers you can see the belts by tilting the washer back . On REAL maytags are two belts on Crosley built maytags is 1 belt
Maytag MAV8557... | Answered on Dec 07, 2010
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Maytag MAV8557... | Answered on Sep 03, 2010
The spin bearing is the culprit. Water works down through the tub seal onto the bearing.
Maytag MAV8557... | Answered on Apr 13, 2010
Check that it is actually heating the water. If it is not, I would suspect the heating element needs replacement.
It is programmed to fill with water - then heat it before washing.
If the water does not heat, it will just wait....and wait.
Maytag MAV8557... | Answered on Feb 09, 2010
bearing or transmission
Maytag MAV8557... | Answered on Feb 02, 2010
the inlet water valve on the back has gone bad,replace it and it should be all right-mike
Maytag MAV8557... | Answered on Jan 15, 2010
YOU HAVE A FAULTY WATER VALVE. IF YOU HAVE HARD WATER CALSIUM CAN BUILD UP IN THE VALVE.
Maytag MAV8557... | Answered on Oct 28, 2009
sorry to say with this model thats a clear indication that the tansmission is gone
Maytag MAV8557... | Answered on Oct 03, 2009
The LF code indicates an inlet water flow problem such as a kinked hose or a clogged screen.
Maytag Washing... | Answered on Sep 22, 2020
hi, what is the model of your washing machine? maybe this website can help you to solve your problem http://maytag.manymanuals.com/washing-machines
Maytag Washing... | Answered on Sep 21, 2020
The cycle timer may have failed.
Maytag Washing... | Answered on Sep 17, 2020
dU flashes if the following conditions occur:
? Excessive force on door lid is preventing lock bolt from retracting.
? Wash media buildup is preventing lock bolt from retracting.
? Machine/motor control cannot determine if door lock is in an unlocked state.
Maytag Washing... | Answered on Sep 16, 2020
Maytag MAV8557 Top Load Washer Logo
25 questions posted
Top Maytag Washing Machines Experts
Sheldon Dedek
Michael Thomas
Michael Thomas
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag lat8210 washes perfectly after
  • Washing Machines
