20 Most Recent Panasonic Lumix DMC-LZ3 Digital Camera Questions & Answers
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
Panasonic Lumix... • Answered on Nov 20, 2014
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
Panasonic Lumix... • Answered on Sep 21, 2014
You may use any MMC or SD card, which top out at 2GB. MMC cards are all but extinct, so I'd go with an SD card. Make sure it's an SD card, 2GB or smaller. The camera will not work with higher-capacity SDHC cards. The brand of the card doesn't matter, though personally I'd stick with the major brands.
Panasonic Lumix... • Answered on May 01, 2014
Are you sure the pics aren't in a separate folder?
Panasonic Lumix... • Answered on Apr 21, 2014
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Panasonic Lumix... • Answered on Feb 25, 2013
What size memory card? If it's larger than 2GB then it's actually an SDHC card and won't work with the DMC-LZ3.
Panasonic Lumix... • Answered on Dec 25, 2012
You may use any SD card up to 2GB in size. Be sure you get an SD card, not an SDHC card.
Panasonic Lumix... • Answered on Aug 11, 2012
Your camera won't deface your pics by scrawling a string of numbers across them. However the date and time (and a lot more) are stored with each file in its EXIF metadata. Just about any photo editor/viewer should be able to show you this data. If you want to print the date, please refer to the documentation for whatever program you use to print your pics. Depending on the program and printer, you may print the date on the image, in the margins, or on the back.
Panasonic Lumix... • Answered on Apr 17, 2012
Is this anew problem digicam flasher are very low energy and only fir for close group work- Will not illuminate a large room for example. But it may be a fault too. perhaps only the anti red eye pre-flash is working and the main flash is not. Check this out with Panasonic tech support team.
Panasonic Lumix... • Answered on Dec 09, 2011
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Panasonic Lumix... • Answered on Sep 13, 2011
Hi, What features are you needing help with specifically? I'm more then happy to help you out =)
Panasonic Lumix... • Answered on Aug 07, 2011
If the pictures are on a memory card, format the card. This should be done every time you finish downloading your pictures to a computer. FixYa is full of people asking how to salvage pictures from a card that hadn't been formatted recently.
If the pictures are in the camera's internal memory, format it.
Either way, while in playback mode press MENU/SET to display the menu, then use cursor-up/down to select [FORMAT]. Full instructions are in the "[FORMAT]" section of the manual (page 78 in my copy). If you need a copy of the manual, you can download one from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/DMCLZ5-MULTI.PDF
Panasonic Lumix... • Answered on Jul 12, 2011
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Panasonic Lumix... • Answered on May 19, 2011
Possible that the SD card is having errors, So take a scan on the card and confirm. Also check the card on another PC to confirm if there are images on the card. If not there can be errrors in the camera. It will be ideal to have another SD card ( borrowed) to be inserted to the camera to confirm.
Panasonic Lumix... • Answered on May 17, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Panasonic Lumix... • Answered on May 09, 2011
iPhoto is for working with still photographs. Try using iMovie instead.
Panasonic Lumix... • Answered on May 03, 2011
Panasonic Lumix DMC-LZ3 Digital Camera Logo
97 questions posted
Top Panasonic Cameras Experts
STEVE
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
lost software cd 39 t download
  • Cameras
