20 Most Recent Panasonic PV-GS36 MiniDV Digital Camcorder Questions & Answers
Use a mike if it has a mike input if not just talk while recording.
Panasonic... • Answered on Apr 02, 2016
The PV-GS36 uses SD cards. Your 16GB card is an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Panasonic... • Answered on Aug 25, 2012
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Panasonic... • Answered on Dec 06, 2010
The PV-GS36 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot it will not work properly. You need to use SD cards, 2GB and smaller.
Panasonic... • Answered on Jul 09, 2010
to transfer video from your camcorder to your pc you will need a firewire cable (ieee 1394). only with this cable you will be able to transer video.
you will also need a firewire port on your pc.
if you don't have one then you can buy a firewire pci card.
see this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
Panasonic... • Answered on Jan 26, 2010
In case anybody read this....     I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera.  In my case it had just become stuck and needed to be gently pried open.    Tested it a bunch of times with tape - seems to be o.k.!
Panasonic... • Answered on Jul 02, 2009
Your camera has a 4 pin port on the side of it next to the USB port.....depending on the type of firewire connector on your computer will determine what type of 1394 cable you will need to connect the PC to the camera. Your computer could have a 6 pin or 9 pin connector (I'm betting it has a 6 pin). Get a 1394 cable that is 4 pin to 6 pin and you should be able to connect the two together....that's how I did it with my tower PC and to my laptop with a firewire PCMCIA card.
Panasonic... • Answered on Mar 16, 2009
quien me puede ayudar con el driver de la camara PV-GS90 gracias
Panasonic PV... • Answered on Jun 08, 2020
If you own a Canon camera and are facing some unwanted errors related to its memory card, then you have come to the right place. While Canon cameras are quite reliable and are widely used the world over, they can be a bit unpredictable. For instance, users often complain of memory card errors on Canon cameras. Don't worry - this will be the last guide that you will read about memory card issues on Canon. We have listed all the commonly occurred errors on Canon and have provided their solutions as well. Let's get it started!
Panasonic Video... • Answered on Mar 19, 2021
Here are the drivers. Contact Panasonic Customer Support for the software package.
USB Driver Update Program for Digital Video Camera ' Support
av.jpn.support.panasonic.com > e_cam > downdvc_usb
Otherwise, there is no need to upgrade. Applicable Driver. USB Driver bundled with Panasonic NV-MX500/GS40/GS50/GS70 (Digital Video Camera); USB Driver ...
Panasonic Video... • Answered on Mar 17, 2021
https://books.google.com.pk/books?id=S_gjI7Gg3IQC&pg=PA140&lpg=PA140&dq=panasonic+sdr+h85+i+was+wondering+if+there+was+any+way+i+can+record+without+picking+up+sound&source=bl&ots=kFAJurZxv3&sig=ACfU3U0Tx7pdbg_1AxeYGxEafwjuyvJptQ&hl=en&sa=X&ved=2ahUKEwikwvu5oN7oAhWvDWMBHaCSCu8Q6AEwAHoECAwQJQ#v=onepage&q=panasonic%20sdr%20h85%20i%20was%20wondering%20if%20there%20was%20any%20way%20i%20can%20record%20without%20picking%20up%20sound&f=false
Panasonic Video... • Answered on Apr 10, 2020
Video Cameras Logo
13 questions posted
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
PV Panasonic
  • PV Panasonic
Most Popular Question
get card error message when install 16
  • Video Cameras
