20 Most Recent Canon CLC 1140 Copier Questions & Answers
Call the cannon support team (877-690-9305) Help you to resolve the issue
Canon CLC 1140... • Answered on Jan 26, 2018
hi how do solve this problem system error E007
Canon CLC 1140... • Answered on Dec 02, 2017
it relates to communication between the boards.remove the rear cover and then remove all the connection of the boards and then reinsert them.then on the machine and go to service mode by pressing * 28 * and then to CLEAR option and clear the ERR. if this not work then u have to change the board.
Canon CLC 1140... • Answered on Jul 27, 2017
The fusing unit needs to be replaced or repaired. Contact your dealer or service person
Canon CLC 1140... • Answered on May 10, 2015
how to solve error code E1 for Xerox printer 5520 work
Canon CLC 1140... • Answered on Feb 13, 2015
Fixing film has been displaced e007
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
Canon CLC 1140... • Answered on Jan 05, 2015
you must chose the bypass try to copy the heavy paper
Canon CLC 1140... • Answered on Jun 12, 2013
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Canon CLC 1140... • Answered on Mar 14, 2013
corona wire is faulty.you have to clean up or replace a new
Canon CLC 1140... • Answered on Mar 03, 2013
needs fuser assembly. probably bad thermistor.
Canon CLC 1140... • Answered on Nov 14, 2012
Why do you want to change the cleaning web? That error code is a laser problem. The cleaning web would be a E0005 code
Canon CLC 1140... • Answered on Aug 17, 2012
Canon CLC 1140 Copier Logo
88 questions posted
old marine
old marine
 Grubhead
Grubhead
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error 000400 0100 canon ir 5055
  • Office Equipment & Supplies
