20 Most Recent Canon ImageRunner 2020i Copier Questions & Answers
operate copier without AUTO
Canon... | Answered on Sep 03, 2016
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Canon... | Answered on Jun 28, 2016
You need to replace fixing film.
its fuser unit temp. rise detection
to reset the error:
Enter the service mode:
press asterix key ( add. functions ) "*"
press 2
press 8
With right arrow, go to CLEAR, press OK, with arrow choose Engine and OK.
Turn off and on.
Canon... | Answered on Mar 26, 2014
replace the fuser film
At a quick glance I found this site. Looks like it will have to come from China.
http://www.tutuprinter.com/list-canon.htm
Canon... | Answered on Nov 22, 2013
A replacement heater element is required as it is not heating correctly.
Canon... | Answered on Oct 28, 2013
see on the back side of the machine .there will be four ports .one USB port ,one LAN port , and two phone jacks in the middle of the cover.in one u have to insert the main line and the other is for extension to the handset.
Canon... | Answered on Aug 17, 2011
check the toner hopper .toner is not being fed into the developer module at set rate.clean the hopper by blowing the toner and check the toner screw motor for rotation and do check when u install toner by service mode does the toner bottle rotate.
Canon... | Answered on Aug 13, 2011
this message is 90% from the second tray.try to close the small door of the 2nd cassette forcefully.if it does not work u can disconnect the second tray by unplugging the wire from the engine board on the back side of the machine by removing the back cover.it will be a yellow p/j in the middle of the board.u can easily trace it as it goes down to the 2nd tray.
Canon... | Answered on Jul 15, 2011
Formate the hard disk or chand the hard disk
Canon... | Answered on Feb 21, 2011
adjust paper sensor
Canon... | Answered on Dec 20, 2010
Check the dial or slider on the side of the cassette tray for size indicator. This will cause jamming and the improper size message. Make sure the indicator matches the size of paper in the tray.
Canon... | Answered on Sep 17, 2010
45 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon ir2020 copier says resizing
  • Office Equipment & Supplies
