20 Most Recent
Maytag PYE4557A Dryer Questions & Answers
My 13 year old Maytag Dryer rumbles to a start
I would check the drum rollers and glides first, the other cause may be the idler assembly which is next to the motor, it keeps tension on the belt. Since you will have it apart you can check the belt for cracks and wear, if it looks good then I would not replace it. eBay is a cheap place to find dryer parts, here is a website on the rollers/glide you can go to the virtual repairman and it will help. I think it is a good site to troubleshoot just about anything you may have problems with, Good Luck Tim.
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
The dryer heats but the
The belt is likely needs replacing. Before taking it apart turn the dryer on and listen for the sound of the motor running. If it is the belt is broken. If not it could be several things ie; motor,timer, shorted or open wire. Here is a link for the belt
Dryer belt replacement The belt is inexpensive and easy to replace. You can also watch videos of the other possible problems at the same site.
Does not work at all
The maytag dryer has a main power board that controls every thing from the light to the heat time. You can change this board but probably it is best a get a new dryer. The board is very expensive because it is the brains of the machine. A technician will tell you to change the board but with the parts and labor it will be costly and who knows if something else will happen. You cannot tell unless this board is changed if there is.any thing else wrong because you need it before the unit will even turn on. I hope this helps you.
Where is the pilot light on a Maytag dryer
what is the model number? free standing pilots have been gone for several years. Google your model number and include parts.
This will give you sites that sell parts.
You most likely have and hot surface ignitor.
What is the electrical capacity of Maytag MDG9700BWW?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=the+electrical+capacity+of+Maytag+MDG9700BWW%3F
Then check related searches
MOTOR: 1/4HP,120 volt,60 Hz,single-phase,thermally protected against overload,auto-reset. EXHAUST:Use a minimum of 4"(10.2 cm) diameter rigid aluminum or galvanized steel duct. Never use plastic,nonmetal or combustible duct. HEAT SOURCE/ELECTRICAL REQUIREMENTS: Electric model- 5,300 watt nichrome helix coil; 240 volt,AC,60 Hz; 30 amp fuse. Gas model-Single port burner with automatic electric ignition; 22,000 BTU/hr. 15 amp fuse. Self-adjusting valve automatically compensates for variation in gas pressure. WEIGHTS (Crated/Uncrated):
What dose it mean F07 Maytag dryer
The F70 indicates a communication error code between the main control on the top left and the user interface on the front. Unplug the machine and remove the top. Check the connection on the board in the white plastic housing on the top left. Next check the connections on the board on the front.
