20 Most Recent
Leapers Accushot 3X40 Cqb Retical Intensified Scope Questions & Answers
What do the terms 3x40 mean
The first number specifies the magnification. The second number is the size of the front lens. "3x40" means a three-power magnification with a front lens 40mm across.The lens size is given because a larger lens collects more light and thus produces a brighter image. A 7x50 will be usable longer after sunset than a 7x35, for example, though neither should be considered as night-vision glasses.
Battery Removing
I have a 2007 ford focus, and the key was locked in the ignition the car will drive, but key will not come out, so i disconnected the negative post on battery, the key came right out but when i put it back on the key is locked in ignition again, what is the solution to this problem.
I cant site the scope
Put the gun in a vise. Look into a mirror and align the crosshairs so that you have one set of crosshairs when viewing in the mirror. The windage adjustment is maxed to the side you are trying to adjust . This will set the parallax of the crosshairs close to zero and allow adjustment in all directions.
