20 Most Recent Panasonic Toughbook CF-27 Notebook Questions & Answers
you might have a corrupted/bad hard drive
Panasonic... | Answered on Apr 04, 2016
The CF47 Panasonic Notebook will
even support Windows 98.
The drivers are located here:
http://help.panasonic.ca/english/support/sandd/softwarequery.asp#
This is the Panasonic Canada Website and
Drivers are still available.
Good Luck
Panasonic... | Answered on Mar 03, 2016
It sounds to me like you requre Win'XP Service Pack 3.
If you are using Service Pack 2 or earlier, there is no
SATA support which is why the HDD is not recognized.
Get Service Pack 3 and your problems will be solved.
Good Luck
Internal wireless adaptors are not made for generic use. Each motherboard used a different design to it. You will have to use a USB type adaptor.
Panasonic... | Answered on Feb 08, 2016
xp requires at least 1g of memory to run and 10 g of hard drive space, if you dont have this it wont install
Panasonic... | Answered on Oct 02, 2013
had same problem with loading win xp proff on cf 74 toughbook mk1.
soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
Panasonic... | Answered on Aug 10, 2013
Boot up with the Windows XP installation CD (you will need the Product Installation code) then proceed to install Windows XP follow the instruction to delete the existing partition - create a new partition - then Format the partition (not a quick Format) - this will wipe the hard disk and install a clean Windows XP system.
Panasonic... | Answered on Jun 16, 2012
Any usb mouse will work. Just get one off ebay: http://www.ebay.com
Click Start/Control Panel and look for Mouse. Look through it for what ever problem you might be having.
If you are saying your mouse/touchpad has a problem then try reinstalling the touchpad driver.
Get online and got to www.google.com In the google search box type: "Panasonic Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
Panasonic... | Answered on May 21, 2012
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Panasonic... | Answered on Apr 13, 2012
if you disconnect the charger and the battery died then that means that your laptop battery is broken and it won't work untill you get a new one.
Panasonic... | Answered on Apr 11, 2012
Web Site
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
Donot enter model# in first slot.
Enter Computers in second
Enter Toughbook in third
Select CF-27E
Everythink is there, two pages.
Manual isn't much use.
Panasonic... | Answered on Jan 15, 2012
Check your BIOS settings and make sure they USB is not blocked in BIOS from booting the machine. By Default the Toughbook series are set to block the USB port from booting the machine at the factory.
Panasonic... | Answered on Dec 03, 2011
You'll need to go to the Panasonic site and download the Bios update from them. for the Toughbook series they normally don't release updates through a 3rd party.
Please click hear to download the manual.
Please let me know if you require any assistance.
Thank you
Panasonic... | Answered on Mar 18, 2011
Panasonic Toughbook CF-27 Notebook Logo
112 questions posted
Top Panasonic Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Toughbook Panasonic
  • Toughbook Panasonic
Most Popular Question
remove windows 98 from cf27 install
  • Computers & Internet
