20 Most Recent Canon DC20 DVD Camcorder Questions & Answers
You might want to check the battery,if the battery is completely dead it won't charge or turn on
Canon DC20 DVD... | Answered on Apr 28, 2014
Do you have a manual? if not go here and download the manual for free. It will tell you how to do it. http://www.usa.canon.com/cusa/support/consumer/camcorders/dvd_camcorders/dc20#BrochuresAndManuals
Canon DC20 DVD... | Answered on Oct 24, 2013
TRY A LASER LENS CLEANER,,AND BLOW IT OUT ,,
Canon DC20 DVD... | Answered on May 10, 2011
Its possible that some internal error is stored in the memory ca,croder; keep in mind that the software in laptops is 64bits while pcs is 32bits. Check and installa the right driver in each device to connected the camcorder.
Hope helps.
Canon DC20 DVD... | Answered on Apr 24, 2011
Try DVD Author Plus, it will backup, copy, and burn your DVD's. It is easy to use and works perfectly. Download the free version here:
http://www.deskshare.com/dvd-authoring-burning-software.aspx
Canon DC20 DVD... | Answered on Jan 17, 2011
You can download the manual (and more) from the manufacturer's web site at
Canon DC20 DVD... | Answered on Jan 14, 2011
you need to install the dvd playback software on the Pc to read the disk. the codec of the camcorder is not installed so the Pc can't read the video format. use for exemple dvdplayer you can download it from this link it's free: http://www.dvdvideosoft.com/products/dvd/Free-DVD-Player-Software.htm
Canon DC20 DVD... | Answered on Dec 24, 2010
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Canon DC20 DVD... | Answered on Dec 23, 2010
Check the laser lens for any dirt or obstruction. If there is, clean it carefully with a "Q" tip and alcohol. Insert a disk and listen for the disk turning inside the drive. If you don't hear anything then something is wrong with the read laser. It's either damaged or burned out. The laser must focus, read, and then spin the disk to not show "no disc".
Canon DC20 DVD... | Answered on Nov 10, 2010
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Canon DC20 DVD... | Answered on Nov 07, 2010
Hello
OK, at the l;ink below you will be able to download the manual in PDF format free of charge.
Click HERE to navigate to download page.
Fell free to contact me if you need any further assistance.
Kind regards
Andrea
Canon DC20 DVD... | Answered on Sep 29, 2010
Tip
Canon DC20 camcorder Manual(PDF)
Hello
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit Canon's official website.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
on Mar 07, 2010 | Canon DC20 DVD Camcorder
You have to change it to supported format such as avi or mpg.
Means, you have to "rip" your video.
I use Xilisoft DVD ripper.
But you can try other software.
This one is free:
http://www.freedownloadscenter.com/Multimedia_and_Graphics/Video_and_Animation_Tools/Super_DVD_VOB_Converter.html
Canon DC20 DVD... | Answered on Feb 05, 2010
hi. in many DVD camcorders. you are suposed to closed o finalize the dvd disk . by doing this it will be playback compatible with your pc or dvd player.
NOTE
after finalizing a disk you will not able to record any longer on that disk (DVD-R, DVD+R, DVD-RAM, DVD RW) If you record for 5 minutes and finalized the dvd it will have a 5 min movie !!!
Canon DC20 DVD... | Answered on Oct 08, 2009
If the camcorder does not read any disk, and makes noise when reading a disk and does not start reading, then the problem concerns either motor assembly or lens pickup.
If the disk is spinning and lens had been cleaned already, then the lens must be replaced.
Canon DC20 DVD... | Answered on Aug 14, 2009
Canon DC20 DVD Camcorder Logo
46 questions posted
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
dc Canon
  • dc Canon
Most Popular Question
when trying video keep
  • Video Cameras
