20 Most Recent Canon ZR700 Mini DV Digital Camcorder Questions & Answers
Your blog posts about Online writing Help are superb.
run 3 cool math
Canon ZR700 Mini... | Answered on May 07, 2018
It's free support and you may end up coming out cheaper by upgrading your camera through their Canon Loyalty program than having it repaired. cool math games
Canon ZR700 Mini... | Answered on Apr 17, 2018
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Canon ZR700 Mini... | Answered on Jun 25, 2017
It is not possible to play directly on this camera as it is an old model.
You should get a cassette player and put the tape in it and connect it to your TV.
Canon ZR700 Mini... | Answered on Jan 29, 2013
make sure you are using 4 pin to 4pin firewire which looks like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Canon ZR700 Mini... | Answered on Jun 21, 2011
As a matter of fact you can capture digital video(HD) using imovie provided you do it correctly. Refer to the PDF below(completely) and try capturing again. You should have no problems
http://www.mtholyoke.edu/lits/assets/lits/imovie6.pdf
Let me know if it worked,
Sai.
Canon ZR700 Mini... | Answered on Feb 03, 2010
Open iMovie and set it to capture DV. (Click the camera shaped icon opposed to the siscor scissor shape) When you see a blue screen that says (camera connected) and the image pops on screen of image from tape on camcorder set in play mode, you hit the import button and it begins to capture digital movie using DV compression of whatever you have on tape. You should be able to control your camcorder with the video controllers underneath the project window to make selections for the in and outpunts on the tape you wish to capture. Then switch to edit mode by clicking on the scissor button and import the movies you just captured or use them from the clips menu, etc. renedr movie back to tape, if you wish by clicking back and forth from edit mode (scissors) and capture mode (camera silo) and render to and from tape.
Canon ZR700 Mini... | Answered on Dec 01, 2009
CONNECT THE CAMERA VIA THE DV -4 PIN CABLE TO YOUR PC ON THE FIRE WIRE CARD -
INSTALL THE CANON DRIVERS FROM CANON WEBSITE
USE A VIDEO SOFTWARE LIKE ULEAD OR WINDOWS MOVIE MAKER
MAKE YOUR CONNCECTION ON THE PLAY MODE AND PLAY THE MINI DV
BEFORE THE PREVIOUS QUOTE MAKE THE AV-DV OPTION ON IN YOUR CAMERA SETTINGS
ALL THE BEST
Canon ZR700 Mini... | Answered on Oct 10, 2009
camera it's showing nothing on the computer.
Canon ZR700 Mini... | Answered on Sep 20, 2008
The monitor you view while recording does not read from the tape where the problem is located, that's why you are not seeing them during recording.
Since they are not visible while recording, the video section is healthy, only the recording is faulty and it is unlikely you can do anything at home to correct it.
This may be a common problem and perhaps Canon is familiar with it.
I recommend you call their service line directly:
email: https://www.usa.canon.com/consumer/controller?act=SupportMailerAct&fcategoryid=227&modelid=12812
Phone: In the US: 1 (800) 828-4040
Canon ZR700 Mini... | Answered on May 14, 2008
Had the same problem, usually when trying to upscale video ! Try reducing size of video on laptop when using transfer software, see if that helps. With my aged laptop, problem seems to be because my laptop has an extremely slow processor chip, and it just can't keep up with the video !
The software I use, which is free, is Freemake Video Convertor, which gives you a choice of output formats and sizes.
Canon ZR Video... | Answered on Mar 16, 2016
Canon ZR700 Mini DV Digital Camcorder Logo
23 questions posted
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
ZR Canon
  • ZR Canon
Most Popular Question
transfer mini dv records pc
  • Video Cameras
