20 Most Recent Canon imageRUNNER 2016 All-In-One Laser Printer Questions & Answers
Nothing displays on screen on IR 2016 . Dear. you may check the flat cable connected with the display unit which becomes faulty . change the flat cable then it will show everything on screen.
Canon... | Answered on May 28, 2018
just clear All. you can try.
press button Additional function - 2 - 8 - additional function - (#SSW on display) press button arrow to search Clear - Ok - press button arrow to search All - press ok. wait until ready (about 5 minute)
Canon... | Answered on May 25, 2018
Dear. first change the drum cleaning blade and clean the waste toner from the drum unit safely and then try to copy if the black lines still appears then change the drum then it must solve the issue , If still the problem comes then check the laser unit if there is anything which produce the black lines on the pages.
Canon... | Answered on Nov 09, 2017
Dear, check all the ccd flat cables of scanner unit and dc boards back side and replace them which are faulty due to long time which lost the metallic strength for which this issue comes .One flat cable is fitted from scanner lamp unit to its board which is long cable and two flat cables are fitted with this scanner board to back side pcb which are long and another one is connected to two pcb boards at back side one comes from mother board to other board,
E010-0000 Main motor failure
The main motor is faulty. - Check the connector of the main motor.
- Replace the main motor.
- Replace the DC controller PCB. http://mfpdoc.com/?mod=free&chap=erc&brand=Canon&model=iR2016
Canon... | Answered on Nov 07, 2017
Dear User,
press additional setting in canon ir 2016 photocopier.then choose language setting tab now select the language by pressing + or - button then save it. it may work.
Canon... | Answered on Oct 17, 2016
REPLACE THE FIXING FILM
Canon... | Answered on Jul 19, 2015
E019 usually means the waste toner is full. The waste toner is, I believe, in the drum, so you'll need a new drum. The drum appears to be under the front cover. You might want to call your service rep. if you are not comfortable doing this yourself.
Canon... | Answered on Mar 20, 2011
Ir 2016, can be onlly pull scanner, so that means that you must have installed scan gear, selected in scan gear, and over microsoft word or similar insert scan ( INSERT PICTURE FROM SCANNER OR CAMERA ), but the machine must be in scan mode, put original on platen or dadf, and then "pull it"from PC.
Hope that helped
pls.rate
Canon... | Answered on May 14, 2010
wich parts do you need? you can write on [email protected]
Canon... | Answered on Mar 01, 2010
to solve this problem, loading the system software to do this, you need the tool called Canon SUPORT SERVICE TOOL
Canon... | Answered on Nov 25, 2009
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Canon... | Answered on Jan 26, 2009
RTFM. Page 34 refers
Setting The Display Language - Canon iR2020 Facsimile ...
www.manualslib.com > ... > iR2020 Series > Facsimile manual
Canon iR2020 Manual Online: Setting The Display Language. If you want to switch the Display Language, select the language you want under DISPLAY ...
VIDEOS as well
https://www.google.com/search?q=ir+2020+change+language
Canon Office... | Answered on Sep 24, 2020
A Fan issue
www.copytechnet.com > ... > Canon
Feb 2, 2010 - my cannon ir 400machine showing e803,e805.plz help me ... For E805 normally it will follow by a few number behind the code that represent ... full e805 code information, as in the subcode for the error E805-xxxx, which will ... Error Code Canon ir 3300, 803 Error code. - Page 2
Mar. 7, 2013
e 804 error - Copytechnet
Sep. 20, 2011
More results from www.copytechnet.com
IR 400 MACHINE ERROR CODE IS E803-000 - canon - www ...
www.oasq.com > ... > Copier Technical Discussion > canon
Sep 11, 2012 - 2 posts - ‎2 authors
IR 400 MACHINE ERROR CODE IS E803-000--Canon imageRUNNER 400S ... E 803 Codes are Coming IN Cannon IR 400 Copier Machines.
Canon Office... | Answered on Sep 15, 2020
In canon printers the most common error code is B200. You'll learn in this article how to resolve canon printer error b200 by self.
The Canon Printer Error Code B200 on the canon printers means that the voltage of the print head or the heat of the printhead is not usual. In certain situations, the b200 error can also result in damage to the print head and being unable to use it, or a problem with the cartridges.
The Canon printers come in two or 4 + cartridges. If you have Four or more cartridges on your printer, you need to follow the instructions below. If you have a two-cartridge printer, skip to the section below.
Step 1: Extract all cartridges.
Step 2: Extract the printhead.
Step 3: The print head is reinstalled.
Step 4: Bring the cartridges back in.
Step 5: Continue Blog - Canon Printer Error B200
It normally stops if you don't install the ink cartridges correctly. When the failure strick on your printer, it will not allow you to continue with the printing assembly. This error can even make the printing process quiet and stable. If you want to experience a hassle-free printing, then you should Resolve the Canon Printer Error Code 1660. First check the main reasons that cause:-
1.Inaccurate fitting of the ink cartridges.
2. Misplacement of the ink cartridges.
3. Cracked or closed ink cartridges.
4. If the print device is not possible to recognize the ink tank then you may view Canon Support Code 1660
Full Blog - Canon Support Code 1660
Canon Office... | Answered on Sep 09, 2020
Canon imageRUNNER 2016 All-In-One Laser Printer Logo
Popular Tags
22 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon 2016 vertical black lines print
  • Office Equipment & Supplies
